hello every body !
today i installed the crank oil seal and the cam oil seal !
but i noticed that the cam oil seal leaks although it's genuine , so i removed it and put it again ! and still leaks !
what can i do !!???????
MIKE
hello every body !
MIKE
can somebody tell me if this is the right part # for the cam shaft oil seal ??? pleease help
91213-PD2-004
this for 5 spd carbed A20A2 !
thnx
MIKE
anyone ???
is there any special procedure to put the seal in ! ???
MIKE
why do you think it's the cam seal leaking?
Eric
how can you tell if its leaking ? i think mines is. smokes sometimes pours from the hood only on the drivers side. already replaced the valve cover gasket twice.
Does anyone have pics or know how to see if the cam seal is leaking?
later !
to know if they are leaking or not remove the timing belt cover ( the upper one ) , run the car till the fan comes on and ask spmeone to press the gas to 4000 rpm several times !
look at the cam while the car is running , any leaks ??
hey sabz !! are you sure about the lubing thing !!??? and what about that moly grease ??? a special grease ?? or high temp !????
guys HEEEEEEEELp ! SHE IS STILL LEAKING AFTER THE NEW SEAL !!!!!!!
MIKE
According to this site: http://www.tpmpinc.com/honda_acura_parts.htm we should have 12341-PH4-000...if this is the right part # for the cam shaft oil seal ??? 91213-PD2-004
You need to lube the cam and inner lip of the seal with moly before you install it. You can pick up moly engine lube at any parts store rather cheap.
Why is the moly needed? Rubber + Friction = Breakdown. Eventually the engine oil will take over for the moly, but right of the bat, it's required.
-5150![]()
we should have 91213-PH1-004 according to this site !
anyway both 91213-PH1-004
and the one i got fits and they are both the same size ! 29 X 45 X 8 any way thnx !
any other ideas guys !
MIKE
