Results 1 to 13 of 13
Thread: Newly Installed H4 Conversion
    DeathRat's Avatar
    Aug 2003
    95 Chev C1500 Truck / 90 Cavalier Coupe (sold)/ 88 Accord LX Sedan (sold)
    Edmonton, AB Canada
    Well I finally did it! I just finished installing APC Diamond H4 Conversion Headlamps with new Jetco 12V 100/55W H4 Bulbs.....Wow! What a difference! I can now turn night into Daylight! LOL I don't think I'll be needing to add any driving lights now mind you either..... Just had to share, as I'm so excited.
    2.0Si User Elijah's Avatar
    A20A3T
    Edmonton, Ab, Canada
    I had just put some on hollys car.
    Busted_Blue's Avatar
    Jul 2003
    93 civic
    San Francisco, CA
    using 100w bulbs on the stock wiring harness actually works? I thought it was not safe to use stock harness with that high input on the harness. Well, I use 60/55w Sylvania Cool Blue at the moment (waiting for silverstars from friend). They look a lot brighter than the seal beams. There is no more tunnel beams that the sealed emmited and i'm wondering the difference if i even chose to get Raybrigs that sheperd mentioned before.
    Gotta love the H4 conveersion, but I'm wondering how long before mine start to leak. The rubber mount on the top doesnt look leakproof at all.
    na
    No, it's not safe, you really should get a new harness and run heavier wire, we've had a few members melt there wires this way.
    you have to choices:
    1. run heavier wire for your bulbs.
    2. replace the bulbs with better quality bulbs that have better output on stock wattage. this is what i have in my car. http://store.racinglab.com/raywhitsonh4.html
    they are briter than any other bulb on the market. this is as close to real HID as you can get.
    SEi User PortugalFocus's Avatar
    Sep 2003
    '13 Civic Si 4dr / 05 Saturn VUE 2.2L 5-Spd
    Clearwater, FL
    Quote Originally Posted by shepherd79
    Raybrig and PIAA bulbs are more expensive than the standard over-the-counter "blue" or "super-white" bulb, but they are very high quality. I have Raybrig H4s in my car.
    A20A3T
    I put PIAA in Hollys car.And went with the bosh housing.
    Mar 2004
    1986 Honda Accord LX-i HB
    Williams, AZ
    Hey just outta curiosity, how much do a decent set of H4 conversions cost? How much watt bulbs can I use on the stock wiring?
    na
    55watt Is the highest I would go.
    SEi User cdscowboy's Avatar
    90 Nissan 240sx coupe
    Corvallis, OR
    I make covers that will prevent water from ever getting into your headlight housings. PM me for details.
    I did the same conversion w/PIAA Xtreme Whites. One of my favorite upgrades I've ever done!!!
    good H4 conversion will cost you about $40-60 for lenses and about $80 for bulbs.
    Quote Originally Posted by cdscowboy
    Those things work great.
    DeathRat's Avatar
    Aug 2003
    Edmonton, AB Canada
    The H4's I got only use the 100W on High beams & 55W on the Low beams.
    I paid much lower than most, as I have my own store & therefore buy at a lower cost. The retail value though on the APC Diamond H4 Conversion Headlamps are around $32 CAN each & the H4 bulbs I got were around $20 CAN each. I'll be only using the High beams for short bursts on dark roads, so I think I'll be okay for awhile. It rained last night & the headlamps remained perfectly dry, so I guess the rubber grommets are working okay for now too.
    When I do replace the wiring to the bulbs.....Do I have to replace the entire harness? or just the wires from the Headlamp switch to the bulbs?
  1. got my sub installed
    By lx-i coupe in forum Interior & Exterior Care
    Last Post: 04-21-2007, 03:13 AM
  2. Newly registered in Napa, CA
    By Eric R in forum Newbie Introductions
    Last Post: 07-04-2006, 02:44 PM
  3. Installed the H&R's...
    By Hash_man_Se_i in forum Suspension/Wheels/Tires/Brakes
    Last Post: 09-22-2004, 04:51 PM
  4. Pics of my newly painted trim and tinted corner lights
    By Micah 89LXi in forum Interior & Exterior Care
    Last Post: 05-05-2003, 11:22 AM
  5. accordboricua's newly painted tails...
    By markmdz89hatch in forum Interior & Exterior Care
    Last Post: 01-19-2003, 05:00 PM
