Results 1 to 7 of 7
Thread: Alarm Install Attempt #1
    89 Accord LXi Sedan
    Northern CA
    Unhappy Alarm Install Attempt #1
    I'm trying to install an audiovox APS150A alarm in my 89LXi. I tapped into the 12V constant, ignition source, and ground wires from my radio wiring harness. Things were going well, (shock sensor and siren worked fine, etc.), until I tried to hook up the wire to pulse to the parking lights. When I armed the alarm, it and my head unit stopped working -- it turned out to be the same problem TeKKnoTeKK had a while back, a blown ECU fuse. I've replaced the fuse, but now I'm scared to hook it back up...
    My question is: Could the problem be that I tried to tap into the radio circuit for power? Maybe the 10A fuse couldn't handle the extra load of flashing the parking lights? If so, where is another good place to tap in? (somewhere at the fusebox maybe?)
    89 Accord LXi Sedan
    Northern CA
    Also, for any wiring experts out there: Is this wire info I got correct:
    Parking Lights: red/black wire, driver's side floor.
    Door Trigger: black/white wire, above fusebox
    The courtesy light switches (door trigger) on our cars are (-) ground output right, not +12V output?
    Thanks a bunch in advance for any help
    LX User 89accordlxi's Avatar
    see user name
    IA
    In my Opinion, I wouldn't tap into anything from the radio harness. Get power straight from battery and ground to chassis.
    parking light wire color sound right, and door triggers are (-) ground.
    That's all I can say.
    Good luck.
    89 Lx-i
    Performance: K&N filter,custom CAI, Accel coil, MSD 6aL ignition, magnecor wires, high flow injectors, FPR, sport exhaust,Tokico springs/struts
    Appearance: white gauges, side markers, headlight conversion, clear bumper signal/fog light conversion, SE-i center armrest and cupholder, SE-i leather seats
    17" ADRs with 205/40/17 khumos
    future plans: 16" or 17" rims(can scratch that one off the list 9-12-02), headers-high flow cat.-cat back piping. Rear disc brakes from SE-i, reground cam.
    RCracer's Avatar
    Sep 2001
    Honda CR-V
    England UK
    I just put a new alarm onto my car and the old one (fitted when i got it) had its power taken from the radio.
    I ripped all that out and took the +from the main fusebox under the hood and I got my earth from a bolt under the trim near the fusebox.
    I had to find all the door/trunk trigger wires so that my alarm can detect the point of entry and keep them seperate.
    Honda CR-V Mk2
    Quantum Sport Saloon
    dj99's Avatar
    88 LX 5-speed Sedan
    Southwest WA
    When i installed keyless, i was told the parking lights wire was the red/black wire in the blue plug at fusebox. Didn't work for me (if i found it at all). I did use the red wire in the white plug at the fusebox successfully.
    dj99's Avatar
    88 LX 5-speed Sedan
    Southwest WA
    Oh, yeah. My door trigger wires were green/white for lock, green/red for unlock located behind the driver kick panel.
    Jul 2002
    1986 Honda Accord LX-i Hatchback
    Malvern, AR
    I have all the Omega books with wiring colors for all cars at my office and I will post it for you tomorrow. I always tap into the 12v and acc. wires on the harness coming down the steering column. The park light problem may be your park lights might be postitive and your alarm may put out a negative pulse or vice versa. If that is case you will have to use a relay.
    Trust in God but lock your car
  1. Alarm install help!
    By Tdurr in forum Interior & Exterior Care
    Last Post: 03-22-2009, 04:17 PM
  2. Help with new alarm install
    By GGR in forum 2geez Accords
    Last Post: 12-22-2008, 01:52 AM
  3. How hard is it to install your own alarm?
    By LxAcc510 in forum Interior & Exterior Care
    Last Post: 06-03-2008, 10:19 PM
  4. alarm install question
    By mouchyn in forum Interior & Exterior Care
    Last Post: 01-12-2004, 01:39 PM
  5. trying to install my alarm (need help)
    By Gregs89AccordLxi in forum Classic Honda Community Chat
    Last Post: 07-17-2003, 08:23 AM
