Post your weight reduction modifications
*Serious Mods Only!
*Must Include Pics!
The usual, do these modifications at your own risk disclaimer applys.
Here is my first one:
REMOVED :
AC / POWER STEERING / EMISSIONS / CRUISE CONTROL
RELOCATED :
BATTERY
REMOVED :
FRONT AND REAR METAL BUMPERS
-- Front bumper removed, metal brackets welded and bolted to the frame.
-- I used a metal rod and flat bars, I used a hand drill to make the bolt holes, I welded the L brackets first, then I bolted the brakets to the frame and welder the rod between the brackets, bending the rod slightly outwards to help support the front of the bumpre skin.
Next shot is a close up of the front L bracket.
Here is a wide shot of the rear...
-- Removed rear bumper, cut metal triagles off of metal bumper, welded new flat bars to the triangles.
Here is a close up of the rear bracket.
