Results 1 to 25 of 35
Thread: Valve adjustment
    Valve adjustment
    Hi,
    I have accord 87 LXI.
    How long can the car go before valve adjustment is really needed - from your experience?
    Any signs of it needed?
    Any consecuences from not adjusting in time?
    Thanks,
    Val
    Dec 2003
    Millington, TN
    Valves should be done every year
    But I went ten years before I did my valve adjustment, just to give you some idea of how long you can go, it varys on driving conditions.
    But the valve become noisy and loss of power and poor gas milage is the result of valves out of adjustment.
    After I adjusted my valves I did notice better response and they did quieted down a bit.
    Hope this helps,
    Phil
    LXi User Silver86LX's Avatar
    '86 LX Sedan (gone), '89 LX sedan
    Barrie, ON, Canada
    Hmmm... maybe I should adjust my valves soon. Is it hard to do?
    - Steve -
    My Accord
    2.0Si User pimp86LX's Avatar
    2005 Mazda 3
    Ontario Canada eh.
    i havn't done it myself, but i've read a few shop manuals and it seems pretty simplisitc.....easy to get wrong for a newb like myself, but simple none the less. I'm going to attempt one on my b20 soon....
    DX User ET2's Avatar
    Jan 2004
    it's pretty easy to do, take the spark plug's out it makes turning the engine over by hand a lot easyer
    Barrie, ON, Canada
    How do you turn the engine over by hand? I know you have to position the pistons at TDC one at a time as you're working on each set of valves.
    - Steve -
    My Accord
    Dec 2003
    Millington, TN
    Crankshaft bolt
    Use a breaker bar @ least 1/2" drive, and take all the spark plugs out as suggested. Put the car in neutral and raise the car if you have the jacks.
    Just take your time and you should have no problem.
    Hope this helps
    Phil
    Barrie, ON, Canada
    I know this may sound dumb, but how do you know when each piston is at TDC?
    - Steve -
    My Accord
    Dec 2003
    Millington, TN
    1342
    This is the firing order of the engine, after you get the engine to TDC as you turn the crankshaft it rotates the camshaft, just rotate the camshaft 90 degrees at a time.
    The marks on the camshaft line up with the heads edge to dictate TDC when you are at the correct point the woud "UP" can be seen in the 12 oclock position.
    I don't type to well so I'm not going to try and describe the entire process. But a manual described this process in detail.
    Hope this helps
    Phil
    1988starter
    Guest
    look in the how to section for my cam shaft how to it gives pics and breefly goes over valve ajustment
    Jul 2002
    88 accord ex-i, 88 prelude Si
    Canada
    Quote Originally Posted by pimp86LX
    doing the adjustments on the b20a is fairly easy. just make sure you have the right clearance and tighten it till theres good friction. all you need is a 10 mm wrench and flathead screwdriver. you also may need a socket set or something with a longer handle to loosen the nuts.
    Now:
    -1988 Honda Prelude custom
    -1988 Honda Accord (to be fixed and sold)
    Soon:
    -some big 4x4 truck
    -91 Acura NSX
    http://www.hatetofeelband.com
    Apr 2004
    Question Just had head/valve regrind Need help adjusting valves
    Hey... I just had the Head on my 86 LX ground including the valves... I have it all back together with a little noise from a couple of the valves... The shop manual says to adjust for Intake 0.005 - 0.007 and for Exhaust 0.010 - 0.012 Now shall I adjust to the middle of each of these? Like for Intake adjust them to 0.006, and for the exhaust to 0.011? What is going to make my engine run the best? Any advice? Tips? Would be greatly appreciated! Thanks guys!
    Jun 2008
    NY
    Re: Valve adjustment
    just reviving this old thread to see what valve adj. intervals you guys use...
    It seems like if the mpg is good, and there's no valve'esque sounds, there would be no need to check the clearances (?)
    1989 Accord LX-I - Brembo f.Rotors, Hawk HP+ pads, ATE fluid
    1996 Mustang Cobra #404 - somewhat stock
    Every 15k miles. If the gap gets wider it's no sweat. If it closes, you can burn a valve. You don't want to burn a valve. And valves getting quiet means that the gaps are closing...
    Dig it?
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    I go through them every time I change a timing belt or perform a tune up. One of the easiest vehicles to adjust the valves imo.
    CARDONE SUCKS.
    Dig it?
    I don't hear my valves at all and the gaps are according to spec.
    Jun 2008
    NY
    Thanks for the input guys!...
    Bragger. I'm coming over to pee on your rims!
    LX User GraniteLXI's Avatar
    Sturgeon Bay, WI
    All of my valves are pretty loud and im guessing way out of spec, 168K and i have no idea when it was last adjusted.
    I plan on getting mine adjusted and at the same time replace all the spark plugs, wires, and do a timing belt kit job (with tensioner) and a new water pump with that as well.
    Out of curiosity what happens if you burn a valve? Or should I say how easy is the repair? lol
    Dec 2007
    so if the valves are adjusted according to spec and you still hear tapping then thats ok? right now mine are quiet except a faint noise from one.... but i know they most likely arnt adjusted to spec.... im making it my mission to check tomorrow since i have some time. i need to get them right for my next trip to houston for my grandpas funeral....
    You want the valves to be adjusted properly, regularly. Don't get too hung up on noise unless it's obvious something is wrong. That's the best I can give you because it's so subjective. I usually adjust mine pretty tight ("a lot of drag" instead of "slight drag") because I can't stand the racket otherwise.
    LX User rfiks's Avatar
    Sep 2008
    88 accord hb dx
    el paso
    i adjusted my valves, i erred on the highest measurement "Chilton's" recommended and gave it a "slight drag". 2maro im guna re-adjust and give "alot of drag" because theres a little valve noise. but so far more power has resulted. after a week i cleaned up my dist. cap and rotor w/ sand paper for a little better spark. its probly all in my head, but i feel a little x-tra power after this also(any advice would be greatly appreciated! thanx in advance!)
    Quote Originally Posted by rfiks View Post
    If it's not too noisy, you're probably good. If you want, try going with "slight drag" on the tightest tolerance. It's a feel thing. After about the 50th time you've adjusted them, you'll have it down cold.
    Nov 2000
    I like the go-no-go feeler gauge set. There are strips on mine that are .005-.007 and .010-.012. Those are the ones for my car. They seem easier because you can feel the drag over a range of clearance rather than a single clearance. It's hard to describe until you use them, but I like them much better than the single ones. Even with proper clearances you are going to hear a bit of rocker noise. That's to be expected with a non-hydraulic valve train. A pretty good Honda guy told me that if you adjust them tight enough to be very quiet that you have the clearances too tight and you risk a burned valve seat.
    I check mine every 20K miles or so. I don't think I have ever had to change adjustments on all of them - maybe about half of them. The newer Hondas - like the Oasis van (Odyssey) I had only recommends checking valve clearance "when noisy." I also don't mess with pulling the spark plugs. The engine's harder to turn, but not that hard.
    Sep 2008
    88 accord hb dx
    el paso
    well i still havent adjusted my valves yet ile get started 2maro morning to make sure the engines nice n cold. im still guna err on the highside but give more drag for a tighter adjustment.....(comments???)
  1. b20a valve lash adjustment!!!!!
    By 3gmodifier in forum JDM B18A / B20A Swap Tech
    Last Post: 01-20-2009, 06:19 PM
  2. valve adjustment w/ new head
    By 88accordSF in forum 3geez Accords
    Last Post: 08-25-2007, 03:59 PM
  3. Got Problems after Valve Adjustment
    By jigga225 in forum 3geez Accords
    Last Post: 12-30-2003, 12:02 PM
  4. valve adjustment question
    By 2old_honda in forum 3geez Accords
    Last Post: 12-17-2002, 12:26 AM
  5. Valve adjustment help?!!
    By 87pimpsterdocious in forum Performance
    Last Post: 09-09-2002, 07:29 PM
