Results 1 to 4 of 4
Thread: Help!
    Andrew's Avatar
    Jul 2003
    1988 Honda Accord LX
    Vancouver, BC
    Help!
    Help, I removed my valve cover to paint it and now I can't remember how the seal goes back in! There are two tabs on one side and one tab on the other, I assume that the two tabs goe towards the timing belt. Am I right or wrong?
    I checked my Haynes manual but it doesn't say anything, I aso loked at the digital pic I took beforehand just in case) but I can't make it out. The seal didn't come with any directions.
    http://www.cardomain.com/memberpage/396598
    Is it just my imagination or does Kalimari kinda look like deep fried assholes?
    Feb 2004
    89 accord lxi
    down by the bay
    Yup, tabs go toward the timing belt. If you look at the cylinder head you'll see that it curves on the dist side and has straight corners on the timing belt side.
    Andrew's Avatar
    Jul 2003
    Vancouver, BC
    Thank God! I went ahead and installed it anyways (bad me, I shoulds waited till someone replied). At least I can drive home without the paranoia. Thanks for your response, much appreciated.
    Feb 2004
    89 accord lxi
    down by the bay
    No problem man, glad to help.
    BTW, did you put some red RTV silicone on the gasket when you installed it? Probably still be ok if you didn't, but the silicone makes it less likely it will leak.
