Results 1 to 8 of 8
Thread: HELP!! I broke something that looks important.
    Hello, Upon attempting to adjust the timing on my 89 dx, (carb) I broke off the vaccume motor thingy attacked to the side of the distrubter, it was not a good idea is what I am thinking.
    The engine was running when this happened, and when It broke, the idle jumped. I am guessing the idle raised by 1-150rpms. So...what does this little unit do, and how much $$ damage did I cause??
    anybody PLEASE.
    I bought a 3g cause I could afford, loved it, now she has become a winter beater.
    My New Car
    YK86's Avatar
    Oct 2000
    BC, Canada
    That I think is the vaccum advance for the distributor. The hoses labelled #2 and #25?? Anyways, you could try drilling a hole tiny bit smaller than the tube that broke off, take the tube that broke out of the hose and tap it into the hole you drilled. Tap it in enough to get the tube to stick but don't go too far. If the hole wasn't big enough use the next size up. Better to be smaller than too big. Hope this helps.
    www.b20accord.com
    Nov 2000
    You can buy a new one from hondaautomotiveparts.com for about $40. My original one got an internal leak and wouldn't hold vacuum so I had to replace it. You definitely need it on there, though.
    umm...I wish it was a hose I snapped off, but it was the whole assembly, it is hanging their, and I can see inside the distributer where the cable is that makes the thing operate (i guess)
    do you know what it does, does it tell the choke how to operate or idle or what??
    My New Car
    well I would guess that upon breaking the assembly the linkage remained attatched and the weight of the advance yanked on the linkage and upped oyur timing *that would cause an idle jump* you need to replace it , it's not too expensive and you can do it with basic hand tools.
    Eric
    Nov 2000
    Just be really careful with the little snap ring that secures the actuator rod to the inside of the distributor. That was the only part that gave me a bit of a challenge.
    SEi User
    81 HB LX, 84 HB S, 89 LX-i Coupe
    Indianapolis, IN
    OT, but I think your valve cover gasket leaks If you haven't replaced it recently, you might wanna do it.
    valve cover leak, I just want the stupid thing to start when I finally sell it.
    My New Car
  1. IMPORTANT!! oil info
    By lostforawhile in forum 3geez Accords
    Last Post: 09-09-2009, 06:06 PM
  2. very important
    By Tim Yoak in forum 3geez Accords
    Last Post: 08-14-2004, 04:26 PM
  3. important
    By chucknice in forum Classic Honda Community Chat
    Last Post: 02-26-2004, 03:57 PM
  4. important
    By chucknice in forum Classic Honda Pics & Videos
    Last Post: 02-26-2004, 07:07 AM
  5. Important Maintanece
    By pimp86LX in forum Classic Honda Community Chat
    Last Post: 08-07-2002, 10:16 AM
