About a week ago I purchased a Throttle body from a local Junkyard for a whole $20 abd began boring it out. I started with like 220 grit sand paper, which just wasn't cutting it so I went to a sanding drum on a 12v drill after I got pretty close to the size I wanted I took 350 grit sandpaper took out all the cuts, then went to 220 and got all the cuts out. Putting it on wasnt that bad but still a pain in the ass, but I got it on and relized that there was a difference between a manual and a automatic throttle body, well where the throttle cable hooked up. I bought a manual and I had a automacit so I switched out the springs and everything got it all hooked up and the idle was at around 3k. So I set the idle screw all the way in and that helped a little, but after a couple of hours the idel just drop, so I had to reset it, and now it runs fine. I will say this is a very cheap and easy mod to do and the rewards are deffently worth the couple of hours to do it. I bored the front out to 65 mm and the rear to 61 mm. I did it in steps so I wouldn't have to get a different butterfly valve. As for my old one Im having a freind take it with him to Votech to be bored out to 68 mm with a acually bore machine. I plan on going back to the junkyard and getting a new air intake manifold to port match, that way if I screw something up I still have one good piece left.
