I wasn't driving so I can only go by what I'm told. On the way home with the LXi, the oil came on. Then alot of clanking noise. After making the turn onto my block the car stalled and coasted to in front of house.
I went out there and checked the oil. It was good. And the fan was running. So then I pulled the valve cover, and started the car for about 20 to 30 seconds. There was a lot of noise and oil sprayed out. Not alot of oil but I'm not sure how much should of sprayed out.
Anyway if the pump is bad, is it worth to change or is the engine already shot? I ask this because a few months ago I went to change the timing belt but couldn't break the crank pulley nut loose. Do I have to get that off to change the pump?
