Results 1 to 14 of 14
Thread: regrind with a carb?
    87accordlx's Avatar
    Sep 2001
    1987 honda accord lx
    Ontario
    hi guys:
    i am serously considering getting my camshaft reground with a mild grind, and i have a few questions first
    1) anyone that has a mild grind on a carbed engine, can u tell me if there was a noticable increase in power?
    2) is it just a plug and play deal, pull the old one, put the new one in kind of thing or does anything else need to be done to accomidate the new cam
    3) this would be my first engine mod, is it a good idea to put a reground cam in a stock engine?
    thanks guys, this board has been great
    scott
    -Scott
    3geez member since Sept. 27, 2001
    "its a shame that our society as glorified the thug life. It just churns out fearless idiots with guns " - Pimp86LX
    Sabz5150's Avatar
    1989 Accord SE-i coupe
    Richmond, VA
    Well, it's not exactly 'plug-and-play', but it's close.
    You'll have to readjust your valve clearances for the new cam. It's a time consuming process, but not all that hard. If you can swap the cam yourself, you can adjust the clearances.
    I'll have to write a howto on cam swapping. I did it in approximately an hour.
    -5150
    glorious!
    87accordlx's Avatar
    Sep 2001
    Ontario
    thanks sabz, does the place that regrinds the cam tell you your new valve clearences?, i am also interested in an answer the my 3rd question, any input would be great
    thanks again
    scott
    -Scott
    YK86's Avatar
    Oct 2000
    BC, Canada
    The valve clearances need to be set to the stock guildline numbers so you don't need to get any new numbers . 0.005-0.007 for the intake and 0.10-0.12 for the exaust. I would also look into getting a new cam seal.
    I highly reccommend this mod for stock and modded cars. A modded car will make the most of it but a stock one will still see gains.
    www.b20accord.com
    Sabz5150's Avatar
    Richmond, VA
    .010 to .012 for exhaust? My exhaust is set to .008, and intake set to .006... Must be dependant on the cam.
    -5150
    glorious!
    YK86's Avatar
    Oct 2000
    BC, Canada
    Those are the official specs. Actually, almost all Hondas seem to go by those specs. Mine's set to .006 and .009 so the exhaust is tightener than specs but it was slapping still at .010 so it does depend on the cam.
    www.b20accord.com
    1988 Honda Accord
    Ontario, Canada
    well when you're ready to do your cam, I'll give you a hand pullin' a core at the scrap yard and help you install the re-grind into the car when you get it back. I'd like to see how its done and 'practice' on your car first Besides... it'll be fun!!
    CoAsTeR
    88' Honda Accord LX
    www.coastersride.cjb.net
    Visit my website for pics and how-to's
    87accordlx's Avatar
    Sep 2001
    Ontario
    deal
    -Scott
    88 LX-i
    ellisville MO.
    i have a very mild cam grind 200/216(@0.050), that 10degrees more then stock. really dont notice much unless i am down shifting to pick the revs up. like everyone is saying YOU MUST HAVE YOUR VALVES ADJUSTED PROPERLLY. if they are to tight you will float your valves, to loose and you will beat your cam to sh*t. you might think about retunning your card, the new cam will drink more fuel. dont send your cam to crower the guy who runs the import dept. has his head shoved in his a*s. i would go to colt or openloop and get a 210/216(@0.050 lobe lift) with 0.350 lift. that should good for a desent increase in power while not eating to much of your MPG, and ta boot you will have -7 degrees of overlap so you get to keep your power brakes which is always a bonus
    I’ll kill you with experience
    87accordlx's Avatar
    Sep 2001
    Ontario
    ummm when i was talking to yasu he said hie MPG went up and he got a decent power kick all throught the rev range, and a big kick after 3000. and how does the camshaft affect the power brakes?
    -Scott
    Instead of a cam if you don't already have a header go with a header for the money and time its better then a cam for more horses.
    87accordlx's Avatar
    Sep 2001
    Ontario
    in order to get any decent power out of a header i have to upgrade the whole exhaust system, that is not in the budjet right now
    -Scott
    88 LX-i
    ellisville MO.
    you will never get the amount of power out of a header that you can get from a cam.
    THE LOSE OF POWER BRAKES FROM CAM- when you start changing the profile of the cam to a more race or higher performance profile the VALVE OVERLAP becomes closer and you lose vaccum. the power brake booster runs of the vaccum of the engine.
    YK86's Avatar
    Oct 2000
    BC, Canada
    I would say that my cam gave me a bigger smile right after installing and drivng it than the header BUT they are very close in increases. It's tough to compare since I never compared each mod to a stock version of the car. Both header and cam gave me better MPG and more power. No problems with braking power.
    www.b20accord.com
  1. Cam regrind , need suggestions ?
    By gr3k0sLaV in forum Performance
    Last Post: 05-17-2006, 07:32 PM
  2. regrind cam
    By shadow lxi in forum Performance
    Last Post: 01-11-2006, 09:29 AM
  3. cam regrind
    By jlaccord89lxi in forum 3geez Accords
    Last Post: 06-27-2003, 04:11 PM
  4. cam regrind?
    By 87 Honda Prelude in forum Performance
    Last Post: 11-10-2002, 11:04 AM
  5. Regrind
    By 89accordtre in forum Performance
    Last Post: 07-11-2002, 08:05 PM
