Results 1 to 10 of 10
Thread: Bose System cuts in and out on 89 SEi
    LX User ag bullet's Avatar
    Apr 2004
    1989 Accord SEi Coupe 5spd
    Raleigh, North Carolina
    Hey there, I just picked up an 89 SEi coupe and the stereo is stock with the exception of a Pioneer 12 changer in the trunk. The audio on the stereo is acting kind of weird and it is a problem I was told about when I bought the car. Basically, the audio cuts in and out. While doing so, it gets really "scratchy" and the volume is varying. I was told they thought it was a loose speaker wire, but I suspect otherwise. The only thing I have not tried when it happens is playing a tape. Since the changer uses an FM station and it happens with the radio on too, I think it could be a loose antenna wire/connection or maybe something with the Bose amp. Thoughts?
    2.0Si User accordlxi2.0's Avatar
    1986 honda accord lx (r.i.p) 1990 acura legend LS
    chicago , il.
    try using a tape first then if it still happen's try to clean the volume knob, and check the wiring connection's.
    i had the same problem with my bose . . .
    Apr 2004
    I played the radio this afternoon hoping it would cut in and out as usual. It didn't act up. I checked all the connections I could as far as the antenna wires, etc and they looked fine. When I disconected one to check it, I got the same staticy noise, so maybe it was a little loose. Guess I will find out soon enough!
    Hash_man_Se_i's Avatar
    Calgary, AB, Canada
    Could be a speaker shorting out... or a fray in a wire, I had that happen in my se-i, and it was just a pinched wire or soemthing lol, but the guys thought it was a shorting out speaker at first.
    Apr 2004
    Quote Originally Posted by Hash_man_Se_i
    This might help me. Was it more prevalent when it was cooler or did it matter? What wire and where, was it pinched?
    chicago , il.
    plus another sign to me was the display everytime i touched the volume the display would dim, and everyonce in a while it would dim when it hit a bass note.
    Apr 2004
    Ok if this helps, it does the same thing with a tape in. So I am guessing either a bad deck or a bad amp. Thoughts?
    chicago , il.
    damn . . .well i say the deck, oh and when my amp went out it just went out well it still work's, but not as good as it used to.
    Apr 2004
    I am gonna try and pull the deck tomorrow to look at the back. From everything I can see in the trunk, the connections are all solid. I am wondering if the factory harness is being strained somewhere and the connections are going bad. Any other suggestions?
    HostileJava's Avatar
    Northampton, PA
    Sounds like there is a short in the deck, I say replace that system one part at a time as you get the money.
  1. System cuts out with bass hits during stops
    By zack_attack2010 in forum Interior & Exterior Care
    Last Post: 07-28-2009, 12:12 PM
  2. bose sound system
    By whuzap in forum For Sale
    Last Post: 06-16-2009, 11:01 AM
  3. system randomly cuts off and restarts ALL THE TIME!
    Last Post: 06-16-2009, 07:57 AM
  4. Is it possible to bypass the Amp-Bose system in a sei???
    By imjdoggie in forum Interior & Exterior Care
    Last Post: 02-20-2008, 07:21 PM
  5. BOSE system and a CD player...
    By offthahook in forum Interior & Exterior Care
    Last Post: 06-20-2003, 06:55 PM
