Results 1 to 4 of 4
Thread: Mysterious Oil Leak
    Sep 2003
    1989 DX (LXI ENGINE SWAP)
    MIAMI
    Mysterious Oil Leak
    17 INCH RACINGHART F24'S 205ZR17- 40 (FALKEN)
    3 INCH DROP
    DC SPORTS HEADERS
    STRUT BARS(FRONT & REAR)
    FULL CAMBER AND CASTER CORRECTION(MIAMI CHASIS)
    TOXICO SHOCKS
    FLOWMASTER EXAUST(2.5 CUSTON EXAUST PIPING)
    CAI, FULL MSD, BOSCH PLATINUM+4 PLUGS
    STAGE 2 CLUTCH, PERFORMANCE FUEL FILTER AND PUMP
    RED AND BLACK LEATHER INTERIOR, PIONEER CD SYSTEM
    JL AUDIO SUBS, HOLLYWOOD AMPS
    ACURA LEGEND ALTENATOR CONV.
    COMING SOON: TURBO, SEI REAR DISC BRAKE CONV. SEI ARMREST &CASSETTE HOLDER.(got my armrest and cassette holder, black with armrest pad in red leather.)
    Sep 2003
    MIAMI
    sorry about the first post but herere is the rundown, I have changed all the seals the bottom oil pan gasket (again) and the head cover gasket, but my car still has a mysterious leak from a very wierd place for a leak . The oil seems like it is leaking from underneath or around the oil filter and dripping onto my mufflers's flexpipie. this is no little leak about a quart every week, maybe longer if I don't push the car over 3k rpm's. Driving like this is killing but I'm putting up with it cause this is my only transportation right now and I put too much money into this car and engine to damage it. Now I have to check th oil everyday just to make sure it doesn't past half way!!!! Howver the leak is not causing the car to idle funny or anything , actually if you didn't knkow therer was a leak the car seams perfect until you park and notice the little cloud of smoke under the car. I need help fast, has anyone experienced a similar problem? Before I let my pride and joy die, I will park it up and catch the bus until I get it fixed.
    3 INCH DROP
    DC SPORTS HEADERS
    TOXICO SHOCKS
    Dec 2003
    Millington, TN
    Oil filter base "Seal" leak
    The oil filter screws onto the oil filter base, which bolts to the engine block via 10mm bolts.
    The oil sending unit also is attached to the oil filter base, must be removed, sending unit screws into the top of the base.
    The seal only cost $4 at the dealer. And is simple to replace.
    Hope this helps.
    NSWST8
    shepherd79's Avatar
    Falling Waters, WV USA
    just replace the oil filter base O-ring seal and you will be set to go.
  1. Mysterious Gas Smell Inside the Car
    By LXlimited in forum 3geez Accords
    Last Post: 12-19-2018, 02:28 PM
  2. Replies: 3
    Last Post: 05-23-2007, 05:58 PM
  3. mysterious looking 3gee......
    By 1ajs in forum Classic Honda Community Chat
    Last Post: 09-13-2006, 02:55 AM
  4. 88 Accord - mysterious oil leak
    By elRuss in forum 3geez Accords
    Last Post: 10-29-2003, 05:04 AM
  5. mysterious rusty water
    By 88LX-i blacknlow in forum 3geez Accords
    Last Post: 09-18-2002, 08:35 PM
