Results 1 to 13 of 13
Thread: Headlight Conversion
    1989 Honda Accord LX-i 2 door
    St. Louis, MO
    Well i just got back from a friends house and we did my headlight conversion with H4's. They are so much better than stock. I don't see how i ever drove around with the stock headlights. Since i was replacing my headlights i decided to go ahead and replace my turn signals and corner lights. While i was replacing my bulbs in my turn signal i went ahead and cleared my turn signals. I can't believe the difference just light bulbs and taking a piece of plastic out can make in appearance.
    LX User cvergi01's Avatar
    Apr 2004
    88 accord lx (for show) / 87 accord lx (for go)
    Duvall, WA
    got any pics?
    LX User NotFast's Avatar
    Dec 2003
    99' Mercedes E320
    Texass
    yea picks would be nice
    -Kelley
    Hondas owned: 84 Accord Sedan Lx, 85 Accord Hatch Lx, 87 Accord Sedan Lx, 89 Accord Sedan Lx-i, 96 Integra Coupe Se
    St. Louis, MO
    When i get home i will take some pics asap! They will be on my cardomain site.
    WA State
    Conversion kits are tight. They make the car.
    S.Glastonbury, CT
    Make sure the H4 housings are sealed up well they tend to leak then your light beam will cut down on output. I used silicone to seal up mine and it worked well but once you get the water in them you will have to take them out and clean the moisture/dirt out and seal them up. Plus the mousture will shatter the bulbs as it did my first set then i just took them apart and sealed them up tight.
    Sep 2003
    '89 Honda Accord LX
    wha exactly does the h4 conversion consist of? besides the h4 headlight bulbs?
    SEi User PortugalFocus's Avatar
    Sep 2003
    '13 Civic Si 4dr / 05 Saturn VUE 2.2L 5-Spd
    Clearwater, FL
    H4 conversion uses a composite housing that utilizes the mounting of your sealed beam headlights. They basically are empty housings that you hook up factory wiring to and replace the internal bulb with aftermarket usually "blue" or "super white" bulbs for improved lighting and visiblity.
    DeathRat's Avatar
    Aug 2003
    95 Chev C1500 Truck / 90 Cavalier Coupe (sold)/ 88 Accord LX Sedan (sold)
    Edmonton, AB Canada
    Quote Originally Posted by RobT5580
    Good Point! I've already re-sealed mine up to keep moisture out.
    May 2004
    what is the part number for the conversion for the headlights and how much do they cost?
    DeathRat's Avatar
    Aug 2003
    Edmonton, AB Canada
    Quote Originally Posted by standardryder435
    Here's what I sell & have on my own car.
    http://www.pureperformancefever.com/...roducts_id=871
    Pics can be viewed on my Car Domain site below in my sig.
    LXi User SharkyX's Avatar
    Mar 2004
    1988 Accord LX-I
    Williamsburg, VA
    whats the diff between your and the ones on ebay?
    RIP: 1988 Accord LX-i
    My Car Domain Site http://www.cardomain.com/id/sharkyx
    Current 1988 LX
    https://www.3geez.com/forum/showthread.php?t=73596
    Busted_Blue's Avatar
    Jul 2003
    93 civic
    San Francisco, CA
    There is no diffference if it is APC too. I don't know the one I have but it has no shield for the bulb. My bulb just shoots out. Is this illegal? I pointed it all the way down already do I wouldn't blind anyone.
  1. JDM / EDM Headlight Conversion
    By 2ndGenGuy in forum 2geez Accords
    Last Post: 05-03-2009, 12:27 AM
  2. NSX HEadlight Conversion
    By troutz15 in forum Interior & Exterior Care
    Last Post: 11-30-2004, 06:14 PM
  3. Headlight conversion
    By urd_86hb in forum Interior & Exterior Care
    Last Post: 04-03-2004, 01:11 AM
  4. 5th Gen Headlight Conversion
    By Twisted 87lxi in forum Interior & Exterior Care
    Last Post: 10-31-2002, 02:05 AM
  5. headlight conversion
    By shepherd79 in forum Interior & Exterior Care
    Last Post: 07-14-2002, 05:50 AM
