ok, so i'd first found the oil leak from the distributor. i ordered the O ring and its somewhat a special order for the dealership. i havent got that yet. they told me check tomorrow. but i'd noticed theres another oil leak on the other side of the engine the the belts are on. i've never been able to see much so today i got my halogen work light under the car and checked things out. damn that things hot! i thought it was the down pipe, but it was the light. anyway, i looked at the front of the engine and it was pretty dry of oil, that was good. i've noticed when i worked under the car many times before that there is always oil on the lower timing belt cover. my first thought was that its the front seal on the crank. but then there wasnt any oil on the timing belt when i changed it out. so i looked at where the oil filter is butted up to the engine, that was dry and all around it was dry. i found that theres oil collecting around the oil pan by the bolts. i think thats it because its the original one and nothing else i can find. i did see that the breather hose on the oil pan is oil soaked. maybe its clogged somehow? i'd be willing to replace that before i tear other stuff apart. the oil pan gasket set was about $14, so i'll be getting that too i think. these mysterious oil leaks suck ass! i know other members know what im talking about. also i'd had some worries about the oil pump gasket thing on the outside of the engine. i dont think thats it though. so if you've got this problem theres some things you can check as i did. i'm going to see about replacing the oil pan gasket, hope i dont have to take the center beam out. maybe i can jostle the pan out. any suggestions about how to change the oil pan gasket easily without much trouble?
