its fried i think its clicking in first gear![]()
hum clicking like how?????
Is it a manual or auto, what exactely does it do? Maybe your oil is low??????
its manual and i went to refill it today cause of the tranny leak but i found out the guy has a crack in the tranny housing bout 2 inches long right under the middle bottom must have got to hot and split cause it din't use to be that long when i owned it so now it won't go into gear. +the terminal cables are so brittle and shitty they are fucked so it wont start now just from me bumpin into them while takin off the intake tube to refill the tranny.
its sad really cause the motor is still perfectly ok with 143 thou on it its just the tranny is fudged...
i'd say go look in a local junk yard for a new manual tranny. thats the best bet if yours is screwed. it'll be cheaper than a new one. see if you can get one for around $100. then you can maybe put that one on and rebuild it later if it needs it. good luck.
well it might want to pull that tranny and take it to a palce to have the crack welded and see whats up with the gears, or just get another tranny at the j/y.
cheaper to get a tranny. like 200-300 hunder dollars. i payed 250 for mine. i mean better off with a used one cuz if u weld it might break again.
