Results 1 to 9 of 9
Thread: Easy Place to get Power for Fog lights?
    Jul 2003
    87 Accord DX
    Hey all, I'm wondering if there is a good place BESIDES the battery to get power for my Pilot Fog lights?
    Thanks!
    Fuzzy
    SteveDX89's Avatar
    2002 Mazda Protege5
    New Freedom, PA
    Get a relay. It will have 4 pins on it. One for battery, one for a turn on, one to the lights and one for ground. I have my turn on lead hooked up with my windshield wipers. This way I can't leave them on by accident.
    Jul 2003
    87 Accord DX
    relay? can u explain more? Mine came with a switch. I was just reading about wiring them to the side markers. Anyone know an easy way to do htis, or will i have to splice into the side marker wiring?
    1988starter
    Guest
    I have mine hooked up to a relay then low beams so they are only on with the lows and are more legal because they are off with the highs
    Jul 2003
    87 Accord DX
    should i just goto the autoparts store and ask for a relay?
    I'm such a noob!
    1988starter
    Guest
    I know autozone sells headlight wiring kits with a relay included
    Jul 2003
    87 Accord DX
    ok, i went to the store and got a relay. but i realized I never got my first question answered. Where do I get power from?
    MY Pilot wiring all ready has a fuse on it. If I need to I can put the fuse on the other side where the power goes from the battery to the fuse to the relay to the wiring for the lights. or can i just keep the fuse where it is and have battery to the relay to the fuse to the lights?
    SteveDX89's Avatar
    2002 Mazda Protege5
    New Freedom, PA
    You will have a wire that goes from the battery to one pin on the relay. That should have a fuse. You will a wire that goes from your turn on source to another pin. You can get that power source from anywhere. Like I said, mine comes from my windshield wipers. That wire should have a fuse. The ground wire and the wire to the fog lights don't need fuses. See if you can take the relay back and try to find a fog light wiring kit. I found mine at Pep Boys. It included all the wires and the relay. You can just hang onto the wires that came with the fog lights for an emergency or something.
    1988starter
    Guest
    low beams and battery for me
  1. Best place to wire into Acc power?
    By bhad133 in forum 3geez Accords
    Last Post: 07-01-2008, 11:35 AM
  2. The best place to buy clear bumper lights?
    By Raynor in forum Interior & Exterior Care
    Last Post: 03-29-2005, 04:48 PM
  3. Power Problems (Lights)
    By MattsAccord in forum 3geez Accords
    Last Post: 02-05-2005, 08:38 PM
  4. Fog Lights With Power Flip Covers
    Last Post: 06-08-2004, 09:33 AM
  5. Easy 25 horse power gain for carb cars guaranteed
    By white87hatchlxi in forum Carburetor Tech
    Last Post: 06-05-2002, 08:26 PM
