89 accord LXi efi. My autotrans will not shift past reverse, the cable is stuck. I unbolted the cover / bracket and can see that the cable is square where it goes into the tubing back towards the shifter. I assume it has twisted somehow and is no longer lining up properly. The corners are rounded over which allows the cable to move enough to engage reverse. I can not figure out how to disconnect the cable from inside the transmission. Also can anyone suggest where to find a replacement?
Thanks!!
Boe
