Results 1 to 19 of 19
Thread: 16's rubbing!
    1986 honda accord
    pico rivera, ca.
    16's rubbing!
    I finally got around to throwing on my 16's. when i went down there they told me the right side of my front axle is broken, so i gotta get that fixed anyone know how much it would cost??? also when i drive with the 16's they rub when i hit a bump or a dip, does anyone know why??? or how i can stop it?
    86LXItooFAST4me's Avatar
    Austin, Texas
    you need new struts
    Car Pics
    vBGarage
    1986 honda accord
    pico rivera, ca.
    Do i need stiffer ones?
    Austin, Texas
    is it lowered? and what is your offset?
    Car Pics
    vBGarage
    AZmike's Avatar
    Tucson, Arizona
    Also, what size are the wheels and tires?
    Mike
    1986 honda accord
    pico rivera, ca.
    195/50r/16 no its not lowered, stock.
    LXi User Bryan's Avatar
    88 Accord DX Coupe 43k miles. Turboed 92 civic hatchback.
    Eau Claire, Wisconsin
    16" 195/50-16 (a tad taller at +2.0%, 205/45-16 is a better choice)
    https://www.3geez.com/showthread.php?t=31782
    88 Accord DX. Custom Mercedes Benz Grey Paint. 16" RS Limited Rival gunmetal rims. Wrapped in Dunlop 205/45/16. MSD Ignition Box 6A. MSD Ignition Coil. NGK Wires. Custom intake w/civic air intake box.2.25 inch exhaust piping. Fireball muffer. Grounding kit.
    1986 honda accord
    pico rivera, ca.
    ok..besides switching the tires.....how can i fix it? also what about the axle, i dont know that much about them so is an axle the kind of thing that can get fixed or has to be replaced???
    Austin, Texas
    well are your struts gone or do you know? does it feel like your in a boat on water when you hit a bump or is it a stiff ride?
    Car Pics
    vBGarage
    na
    Need to know the offset of the wheels, that may be your problem.
    1986 honda accord
    pico rivera, ca.
    not like a boat in water, but if i had to choose between boat and stiff, id pick like bein on a boat, but its a little bit of a stiffer ride since i put on the rims, but i heard thats normal right?? cuz they are thinner tires also, i dont know what the "offset" is how can i find that out???
    Austin, Texas
    Quote Originally Posted by Bryan
    read that.
    Car Pics
    vBGarage
    1989 honda accord lx
    portland, oregon
    it's the tires. running 50's on a 16 rim will do that and rub a lot. believe me....been there.
    LX User 88ebrake's Avatar
    Mar 2004
    88 lxi sdn
    CHATTANOOGA,TN
    it shouldnt be rubbin ive seen an lxi dropped wit 16s and they never rubbed
    Mar 2004
    88 lxi sdn
    CHATTANOOGA,TN
    he had 50 series tires too
    a pile of lawn ornaments
    Newtown, CT
    Quote Originally Posted by HostileJava
    Jim's right. It's most likely your offset. No matter if you have the right tire size, or if you're on stock height, or lowered. And no matter if you have bran-new struts or bad, blown struts. If the offset is too low, then no different tire size on those wheels will keep it from rubbing.
    Question, How much of the tire rubs? Where on the tire is it rubbing?
    If it's just the sidewall of the tire getting a little rash, then rolling the fender lips could solve the problem. If the rub is more on the tread, then I would suggest a different set of wheels.
    -Mark D.
    DX User nanaimo_honda_accord's Avatar
    Jun 2002
    1988 Honda Accord EX- i
    Nanaimo, BC, Canada
    i had 205/50R16 tires on 16X7.5 wheels with a +42 offset and it never rubbed even with a 1" drop. i just put on 215/45R17 tires on 17X7" wheels with a +40 offset and it only rubs when i go fast on a part of the road near my house where the road dips down then comes right back up.
    LX User 89dxowner's Avatar
    May 2004
    1979 Chevy LUV
    Oroville, Ca.
    Mine is dropped on 17's and they dont rub. Thats also after i rolled the inner lip of the fender up and took off the surounding rubber around the wheel well.
    86 Honda Accord LXI HB 5-sp
    Central California
    I'll bet he has a offset in the mid to hi 30's (35mm to 38mm). One catch to fender clearence is this. The taller you go then oem with your tires, the closer your tire goes to any rub points. Since his tire's are taller then oem, the does not help matters. But from the sound of it, the offset is wrong too. To hopefully solve the problem, try rolling the rear fender lips.
    Now I d
  1. ST sway bar is rubbing
    By Legend_master in forum Suspension/Wheels/Tires/Brakes
    Last Post: 05-24-2007, 02:01 PM
  2. rubbing question
    By b8er in forum Suspension/Wheels/Tires/Brakes
    Last Post: 08-28-2005, 02:19 PM
  3. rubbing
    By dub88acc in forum Suspension/Wheels/Tires/Brakes
    Last Post: 11-06-2004, 12:45 AM
  4. Axle rubbing?
    By 88accordlxcarb in forum Suspension/Wheels/Tires/Brakes
    Last Post: 10-12-2004, 06:07 PM
  5. rear rubbing
    By accordster in forum Suspension/Wheels/Tires/Brakes
    Last Post: 05-15-2002, 05:15 PM
