Results 1 to 10 of 10
Thread: Weber Air Filter clips keep falling off
    I just put on the Weber carb and it works great!
    My only problem is with the Weber air filter housing. The 4 clips that hold it together keep falling off.
    1. How do you keep those clips on?
    2. Is there a different air filter setup available for the Weber?
    Thanks for your help.
    did you set the clips into the grooves and the top and bottom of the air cleaner... the bottom grooves are harder for the clips to hang onto because the lip surrounding the carb barrels usually gets in the way... if you can snip off a small bit of metal from the clip somewhere near the end after the little bend in the metal... then use that side of the clip to hook ontop the bottom and leave the top of the clip untouched.
    I hate those clips I'm about to ziptie my lid! >
    1987 Hatchback phreak project
    NORTH BAY ONTARIO
    dxsquared runs no filter
    Travis
    Yes, I had them in the grooves and ground off the tips on 2 of them but I keep losing them. I think my hood might be hitting the filter - which would take pressure off the clips and let them come off.
    Is there another type of filter housing???
    how doesn it hit? mine only hit after I got the taller fitler...
    Justin86's Avatar
    Medford, Oregon
    Hum thats weird I have had no problems with mine staying on.
    Sep 2003
    1988 Honda Accord
    Portland, Oregon
    are you using a thick gasket between the filter and the top of the carb, that sould give enough room so that the clips can sink into the grooves at the bottom as well as the top without having the carb lip interfere.
    A20A1, I think you have it.
    I got 2 new clips. Instead of snipping or grinding the tips off of them, I pressed them into the gasket between carb and the base of the filter housing. Then i tightened the housing to the carb - which should secure them.
    Also, I put some duct tape on the top of the clips (temporarily??) just so I don't lose them again. Hopefully, I'll be able to lose the ugly duct tape.
  1. My car is falling apart!
    By mix4 in forum 3geez Accords
    Last Post: 03-23-2007, 08:37 PM
  2. weber air filter
    By dub88acc in forum Carburetor Tech
    Last Post: 11-05-2006, 10:44 AM
  3. weber air filter MAX height
    By dXsquared in forum Carburetor Tech
    Last Post: 08-13-2003, 03:40 PM
  4. molding clips
    By LIL'LXi in forum Interior & Exterior Care
    Last Post: 01-14-2003, 08:35 AM
  5. Car is f*ckin falling apart
    By AccordLX-i87 in forum EFI Tech
    Last Post: 10-17-2002, 08:47 PM
