Results 1 to 25 of 39
Thread: 1989 accord died, need advice
    Sep 2003
    So I was driving down to philly this past weekend to see my mom for mothers day. I was cruzin along and all the sudden I heard a snap, then the car dies. Tried putting it back in third to try to pop start it, nothing, sounded like the engine was spinning real fast like it lost compression...
    Got to the side of the road, pulled timing cover, belt looks fine, teeth on belt look good. Crank engine over with starter timing belt doesn't move. Push car in gear while watching timing belt no movement (had some freinds with me at this point). Closer inspection revealed that the timing belt would vibrate but it wasn't spinng. all accessorys we're spinning, but not the timing.
    Haven't had much time to look yet but what do you all think? It only had 115K miles on it.
    Sep 2003
    Sep 2003
    ohh yeah, obviously I took the timing cover off to see what was going on. Im geussing that Ill need to try turning the crank over and seeing what it feels like.
    Nov 2002
    Ridin Dirty in New York
    looks like youve already found the problem, install a new timing belt. If i were you id also install a new water pump at the same time, but only use a geniuine honda one.
    Sep 2003
    The belt looks perfect though, you think it chewed up all the valves?
    SEi User Dibbs's Avatar
    May 2003
    '86 LX-i Hatch
    Houston
    Quote Originally Posted by conquestpa
    did you take off the lower timing cover as well? WHen I threw mine years back, the belt looked perfect up top but when I took the cover off, all the rubber teeth were stripped.
    Quote Originally Posted by kroy
    Mad props to you if you can pull it off, you can change your name to slowassoldschoolswap :thumbdown
    Vinny's Avatar
    Aug 2003
    Here, not there
    The only thing that connects the cam gear and the crank is the belt. If the timing gear isn't turning than more than likely the belt is bropken. Grab the belt at the cam gear and pull on it, see if its broken at the bottom where you can't see it. As far as the valves, here we go with the interference vs non-interference arguement. If the belt did break, from what I know myself, the valves should be fine.
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    Either you broke your timing belt or you snapped of the key in the crank. I've heard of that before. If the belt is still in one piece then that might be your problem.
    Nothin' 2 Old Racing
    Sep 2003
    Thanks Men, Im thinkiing that the key broke... I stopped by this mechanics to ask if I could borrow his tow dolly and told him what happened. He grabbed a book and said... Emmm you probably bent the valves... Not sure if he wanted my money or if he was just trying to help.... who knows. In any event im goin got need a new water pump, timing set and I may pull the head and put a new head gasket while im in there. praying that the top end is OK as well as the bottem end... Ill let you guys know...
    Dec 2003
    Millington, TN
    That sucks!
    But Is the belt tight, if not could have just lost the tensioner. Since you said that all the other crank pulley accessories are still moving if you lost the crank key then the crank pulley wouldn't move.
    I'd side with Vinny that its a safe bet that your valves are okay.
    Just a new belt is about right, when was the last timing belt done.
    Hope this helps,
    NSWST8
    Sep 2003
    Not sure yet, hoping to dig into it ummm hopefully this weekend. 13 hour days are killing me. the car 116K and I just bought it about 6 months ago. At least it got me through the winter...
    Vinny's Avatar
    Aug 2003
    Here, not there
    Correct me if I'm wrong but isn't the crank gear the only thing on the crank with a key. Isn't the actual crank pulley made to fit into the notch on the crank? I should know this since I just did the timing belt and all the oil seals but for some reason I know theres a seperate key for the gear but I don't recall one for the pulley
    2.0Si User accordlxi2.0's Avatar
    1986 honda accord lx (r.i.p) 1990 acura legend LS
    chicago , il.
    plus you said the belt vibrated too but did'nt move, i think the belt teeth are stripped at the bottom.
    plus your valve's are fine, . . . . . .
    Sep 2003
    Hopefully Ill be able to tell what happened this weekend. I doubt Ill be able to get it running anytime soon, but I'll take a look and let ya ll know what I find out. Beside this is the reason I have a motorcycle.
    at the very least Ill need to do the timing belt replacement, water pump, and Im thinking of replacing the head gasket while im in there.
    I geuss I could look in the spark plug hold to try to tell if the valves are bent....
    Thanks for the help guys
    Aug 2001
    1988 Accord DX 5spd
    Dayton, OH
    I can almost guarantee the teeth are stripped. Had it happen to me.
    You can tell if the valves are bent by checking the compression. Put the cam at TDC and crank the engine and check the compression on all cylinders.
    Sep 2003
    Update!!! No Bent Valves!
    I decided to just pull the head. Finally got around to doing it. Taking it off wasn't that bad. Getting it back on will probbaly be the hard part. Anyway it looks pretty good. The exhaust valves are a little white. Their was a little bit of grime in cylinder 2. Some left over anti freeze spilled into one of the cylinders. Cleaned it up best I could. I pulled the head with the manifolds attached. Once I got it out I removed the manifolds and then put the head back on temporairily to try to keep things from rusting up. The head gasket looked pretty new. Didn't get into the lower part of the timing cover to see whats going on down there. Im still wondering if the key broke that holds the lower timing gear, the teeth on the belt stipped off (seeing no evidence of that on the part of the belt I can see), or it the lower timing gear stripped the teeth off. I geuss that will be my next thing to look at.
    QUestions:
    should I worryt about the white valves? THe grime? The small amount of antifreeze spiller in one of the cylinders?
    Should I have the cylinder head tested some how?
    My plan is to replace the gaskets in the top end (head gasket etc...), timing set belt set, and water pump.
    Anything else you can recommend doing while im in there? The car has about 120K on it.
    Quote Originally Posted by locknload68
    chicago , il.
    just wipe it out, it'll be fine.
    if you want you can clean the valve's too, so wait you got a blown headgasket??
    well in one of your previous post you said you could see the belt vibrat but not turn.
    then you also said that all the other acceries were turning, but not the belt.
    now as vinny said that if the key was broken.
    someone else had this same problem.
    BTW, your like the 7th, 8th timing belt victim, all those tim'e you kept cranking . . . . ..
    ****** 1994 nissan maxima SE ******
    Sep 2003
    Kept cranking? Im assuming that you mean that I kept running without attempting to replace the belt...
    its true, but I only put about 10K on the car before it blew...
    Ill let you all know more when I have more time to look at it...
    Quote Originally Posted by accordlxi2.0
    Sep 2003
    Ok, next, how do I get the timing cover off.? I assume Ill need to pull the main pulley off but how? Put in gear and yank on it? clock wise or counter?
    Sep 2003
    Ok, sounds like everyone is having this problem. Is it possible to put a wrench on the crank bolt and a jack under it then jack up and hope the weight of the car breaks it?
    Moodybluesr's Avatar
    Jan 2004
    1991 Subaru XT6 AWD, 1988 Subaru XT6 AWD
    Urbana, IL
    Buy one of these:
    http://cgi.ebay.com/ws/eBayISAPI.dll...322890269&rd=1
    to hold the crank pulley in place while you remove the bolt (counterclockwise).
    The chain wrench should be available locally; I got mine for about $8 off-brand and have used it for every timing belt I have done.
    Vinny's Avatar
    Aug 2003
    Here, not there
    Wouldnt suggest doing that. Theres several ways you can do it and thats not one of them.
    I've set a prybar in the timing inspection hole to wedge the flywheel so the motor doesnt turn over. Works well if you have a 5 speed
    Remove the numer 1 plug and run some rope into the cylinder hole when the piston in all the way down, As it comes up the rope will prevent the piston from moving any further up and basically hold the crank in one place. Seen it done, did it myself a few times on bigger engines
    Take it to a local shop and see if they will break it loose with and airgun for you.
    I'd go with number 3 myself
    Sep 2003
    why is it a bad idea to jack on a wrench under the car???
    Head is already off the car.
    Going to pick up one of those chain wrenches today.
    2.0Si User Elijah's Avatar
    Nov 2002
    A20A3T
    Edmonton, Ab, Canada
    I would make sure you do the valve seals well your at it.That is where your getting your white grim.It means they leak.
    Sep 2003
    still cant get the pully off, how can I keep the crank from moving while yanking on the bolt???
  1. 87 Accord LX died while driving...
    By OptimusPrimeSr in forum 3geez Accords
    Last Post: 12-02-2009, 06:47 PM
  2. hmm found out why the accord died
    By AccordEpicenter in forum Performance
    Last Post: 10-03-2004, 08:27 AM
  3. Accord finally died
    By baron4406 in forum Carburetor Tech
    Last Post: 12-16-2002, 06:07 PM
