Results 1 to 6 of 6
Thread: smoking problem
    Mar 2003
    1988 Honda Accord LX, 1996 Chevrolet Cavalier Z-24
    KY
    smoking problem
    okay, im stuck between 2 ideas here. when i drive my accord on the highway, then get off at an exit, the thing wants to stall. then when i hit the gas or get back rolling again...it starts smoking badly. now this car didn't do this before i put the weber on it. but as i look back, the smoke seems to look blue.
    have any of you dealt with this? any others have any ideas on what's wrong? i'm thinking it's either valve seals or the carb flooding after being on the highway. let me know what u all think.
    Brendan
    http://www.cardomain.com/memberpage/520751/1
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    blue smoke means you're burning oil which means either your valve guides are bad or you have a bad ring (rings) that are bad.
    i dont know why theis would have happened after you changed carburators, but it could be just coincidence.
    Nothin' 2 Old Racing
    2.0Si User accordlxi2.0's Avatar
    1986 honda accord lx (r.i.p) 1990 acura legend LS
    chicago , il.
    don't let it fool you, when my engine was flooded the smoke would apper a blueish-gray smoke.
    it's a flooding problem check to see if your float glass is full of gas if it's too much it causes this to happen.
    Mar 2003
    KY
    i feel stupid asking this, i'm more knowledgeable on FI cars, but this in the fuel bowl? exactly what am i looking for? thanks for the help.
    Brendan
    LX User 88ebrake's Avatar
    Mar 2004
    88 lxi sdn
    CHATTANOOGA,TN
    the float bro smell the smoke if possible and see if it smells like oil or not also this will tell u if its rings or not
    Blkblurr's Avatar
    Jan 2004
    Dayton, Ohio
    THe fuel level in the bowl should be at the proper level so that you get the proper fuel pressure to the jets. That level is controlled by the float.
  1. ET2 head on ES2 block? Smoking problem...
    By MustardCat in forum 2geez Accords
    Last Post: 10-04-2020, 12:59 PM
  2. engine eletrical problem, smoking
    By A18A in forum EFI Tech
    Last Post: 08-05-2007, 04:48 AM
  3. Smoking, in the bad way
    By SmokeyTheBear in forum 3geez Accords
    Last Post: 08-27-2006, 11:43 AM
  4. got car back together... smoking now
    By Stockli in forum 3geez Accords
    Last Post: 09-01-2005, 05:59 PM
  5. Smoking at WOT
    By mag_pbg in forum 3geez Accords
    Last Post: 06-26-2005, 09:26 PM
VigLink badge
