Results 1 to 25 of 32
Thread: gutting cat?
    SEi User i.c.'s Avatar
    97 f-150, 1989 accord dx (broke), 91 lx wagon
    columbia, south carolina
    gutting cat?
    theres this guy with a civic with a "gutted cat?" i think that's what it is....it had a stock exaust on it but that was no stock exaust....it sounded like a civic going through a tunnel? anyway....i was wondering if this is a real mod or is there something i can do for pretty cheap to make my car sound a little less weak...thank
    dylan
    1991 honda accord lx
    rockin the SOHC again for now
    h23/vtec in the works.
    Justin86's Avatar
    Medford, Oregon
    gut that cat or run straigt pipe, and cut the muffler off. This is the first thing I did and it sounds bad ass.
    Quote Originally Posted by Justin86
    how do you gut the cat?
    dylan
    remove the cat, and get some kind rod and start chipping stuff sway.
    Quote Originally Posted by shepherd79
    that's it?
    cool....is it just bolted in...i'm trying to get an idea of what kind of job that is
    dylan
    1987 Accord LX-i hatchy
    Seattle
    don't forget to get same one to pass emisions
    check your reaction HERE
    find 3 differences HERE
    emissions? we don't have that in sc...everybody with a modded car around here either has strait pipes or side pipes
    dylan
    Bucket
    Bay Area, CA
    ummmm well taking the cat off, the only hard part is taking the rusted nuts off, first you gotta take the heat shield off, there's 2 pieces for the heat shield and like bout 6 nuts, then the cat is revealed, there are 3 bolts w/3 nuts on each end of the cat, those and the heat shield bolts are usually rusted as hell, you'll need bolt loosener, though i didn't just used a breaker bar. after you get the nuts off, dont try to hammer the bolt out of the cat, it wont go since they are welded on. you'll have to use a shit load of force, bend the exhaust pipe to where the bolts are free and the cat will come right off. wat i did was, on one end of the pipe there were some rusted nuts on the pipe, i used a ratchet on the nut to bend the pipe a little just enuff for the cat to come out. the book says you have to support the frexpipe with wires and junk becuz a hanging flexpipe might have enuff force to crack the header, which i doubt since they're cast iron, impossible to break. now, just do wat shepperd says, take a hammer and rod and bang the shit out of the honeycombs. when you put the cat back on, the nut tightening specs are 22 ft lb, but don't worry bout it just make sure you tighten it hella hard that it wont fall off. although i've hearb people say that gutted cats will have turbulance making the car rattle or comecrap. i'd go witha test pipe but good luck with wat ever you chose to do. and as always have fun. oh btw: dont even bother putting the heat shield back on, it's not all that usefull.
    3geez for life.
    LX User cahil_1's Avatar
    Apr 2004
    89 Accord LXi ==== 94 Civic DX
    MI
    strait pipe it you'll feel so much better afterwards.
    LX User P|eszczoH's Avatar
    Nov 2003
    2 x 1989 Honda Accord Aerodeck 2,0i Exclusive Edition(lather, and one with A/C)
    Warsaw, Poland, Europe
    Quote Originally Posted by 88accordhb
    get Your car Hot, I mean verry hot, like one or two hour driving, and than put it on a dry grass and watch it burns.
    I would say it can be usefull.
    see Ya
    have a nice ride
    P|eszczoH
    Robs89LXi's Avatar
    May 2003
    '89 LXi Coupe
    Keep the heat shields. They are there for a very good reason.
    SEi User PortugalFocus's Avatar
    Sep 2003
    '13 Civic Si 4dr / 05 Saturn VUE 2.2L 5-Spd
    Clearwater, FL
    Quote Originally Posted by Robs89LXi
    I agree heat shields are there for a reason.
    Steps to gutting a cat:
    1 : remove cat
    2 : root around in there with a stick until you can see through side to side
    3 : reinstall cat
    Mike's89AccordLX's Avatar
    Mankato, Minnesota
    If you gut the cat don't bother to put the heat sheilds back on. I've had my straight pipe on for over a year and I don't have any heat sheilds under my car. If you think about it the cat won't need heat sheilds anymore since it won't get as hot as it used to when it had all the honey comb stuff in it. When you don't have the honey comb stuff in the cat it won't get as hot as it used to. Believe me I have driven and parked on grass with my straight pipe and no sheilds.
    Nov 2003
    Quote Originally Posted by Mike's89AccordLX
    empty cat is a little bit thiner than a straight pipe, also its made with a little bit different materials, and it gets hot maybe not like a full cat, but stil hot.
    I would keep it as long as it is not a straight pipe. But You dont have to just be careful and everything will be alright.
    Good luck.
    have a nice ride
    P|eszczoH
    k-roy's Avatar
    87 LX
    Quote Originally Posted by i.c.
    Man this is a bueatiful state.
    Mankato, Minnesota
    Put it this way have you guys measured with a temp gun the heat of the exhaust? I have done this in school on a cat. only gets really hot b/c of all the honey comb pieces inside made of all kinds of precious metals. Without that stuff in there it won't get as hot as a regular cat and will have the same heat range as the rest of the exhaust system. I've tested my prelude and my accord. My accord exhaust down pipe was 175 deg. at one point and then I with the gutted cat it was the same. When I put my straight pipe on I re-tested it and the results were the same but this time the entire exhaust system was 200 deg.
    Put it this way I have tested it so I know what it does and doesn't do. If the regular exhaust piping gets so hot then why isn't there a heat sheild on the muffler, down pipe, and the rest of the exhaust system. That's why there's only a heat sheild on the cat (and header if you want to be picky) b/c of all that honey comb stuff makes the cat so hot b/c it's oxidizing unburned fuel so it's burning unburned fuel and that's what causes the extra heat. So if you bust that crap out then it wont oxidize the unburned fuel and the heat will be the same as the rest of the exhaust system.
    -Mike
    If this doesn't prove that I'm right I guess you guys just need to try it and test it like I did and take a college class like I did on emissions systems so you can understand it better.
    Bucket
    Bay Area, CA
    yes, i was gonna say that, all that! lol jk, but yah...with the honey comb inside the heat is squeezed thru, and the friction caused by the freeflowing heat, let's imagine, "molecules" hittin and stopping, then squieezed thru the honeycombs will cause lots of heat. without it, the heat is free to flow right thru.
    3geez for life.
    Vinny's Avatar
    Aug 2003
    Here, not there
    I had my cats gutted on my old chevy pickup. They lined the bottom eith lead so if they ever inspectd it and tapped on the bottom they didn't sound hollow. They used an air hammer to break all the crap out of them
    10/Honda/Ridgeline
    NJ
    We all know why and what the honeycomb is inside a cat, its the catalyst. But the reason the cat has a heat shield is different. The heat shield traps the heat in and prevents heat radiation. This concentrates the heat buildup in a control environement. THe catalytic converter needs to operate under hot temperature and a lil bit rich exhaust gas to work its full efficiency. Thats why your emission readings are off the scale at cold start than compared to ur reading after 5 minutes of driving. Its not that the honey comb stuff makes it too hot, its the heatshield that is around it makes the cat operate better. no matter if u gut the cat or not, the heat is the same, since there is heat loss due to dissipation from the header, downpipe, catback and muffler, the temperature of the gas coming out of the tip, is not the same as the temp of the gas coming out of the header.
    Bucket
    Bay Area, CA
    who the hell cares about radiation and pollution besides the government? lol jk.
    3geez for life.
    10/Honda/Ridgeline
    NJ
    heat loss due to radiation lowers ur exhaust gas velocity fella which u dont want do you, do you, do you, do you???
    Justin86's Avatar
    Medford, Oregon
    heat sheild's, we don't need no stinking heat sheild's. The only reason a cat get hot is cause of the after burrning process of the fuels. If you gut the cat that process won't happen and it won't get that hot, so no reason for the sheild. Also how many of use actually park on dry grass. Come on I want to see a show of hands here, cause I park on pavemant.
    Bucket
    Bay Area, CA
    wth do i want my gas to go fast for?
    3geez for life.
    Bucket
    Bay Area, CA
    oh btw: this doest belong in the performance section, because it won't give you any hp. unless sound belongs in performance.
    3geez for life.
    Justin86's Avatar
    Medford, Oregon
    This is the point where I go wned:
  1. Gutting a 2g... (Lots of pics).
    By 2ndGenGuy in forum 2geez Accords
    Last Post: 01-02-2007, 10:38 AM
  2. Gutting the hatch
    By bluboomlxi in forum Classic Honda Community Chat
    Last Post: 08-27-2005, 05:36 PM
  3. Gutting Cat
    By Slamed89Accord in forum Performance
    Last Post: 12-05-2002, 11:55 AM
  4. gutting cat....
    By 87AccordsterLx in forum 3geez Accords
    Last Post: 12-03-2002, 11:08 AM
  5. Catylitic Converter Gutting Question
    By Mike's89AccordLX in forum Performance
    Last Post: 10-25-2002, 08:06 AM
