Results 1 to 13 of 13
Thread: Brake preoblems
    SEi User MattsAccord's Avatar
    Feb 2003
    1986 Honda Accord LX
    Southern Oregon, Medford
    Brake preoblems
    This message is for Justin86 his computer broke. :thumbdown:
    He is in the process of doing a big brake upgrade and the rear Se-i brake conversion. The problem the peddle in mushy he has bled his brakes multiple times and the peddle dosen't get very stiff stays mushy. When the engine runs there is no peddle at all right to the floor. Changed brake booster, master cylinder, proportioning(sp) valve and still dosen't work. Any help will awesome.
    Vinny's Avatar
    Aug 2003
    Here, not there
    Did you guys bench bleed the master cylinder? Double check to make sure nothings leaking or loose letting air back into the sytem. Bleed furthest to closest even though the manual says bleed drivers front, the pass rear, then pass front, then drivers rear. If the lines were open to do the front and rear work there may be ALOT of air in there. I'd start with one wheel and bleed it until the fluid runs clear, just to make sure all the old fluids out. If the fluids clear theres less chance that you may have missed any air pockets. I know Justins in a rush to play with these new brakes. If nothing else and he decides to call it a day you can always gravity bleed them.
    May 2003
    88 Accord LX 88 Accord LXi
    You might want to recheck everything. It sounds like you changed almost everything. Make sure all the lines are tight, and all the bleed valves are completely closed off. And check the vacuum to the booster. Sometimes when you do alot of work you mistakenly over look something minor. You said with the engine running the pedal goes to the floor. Did he pump the brakes several times with the engine running? Sometimes you have to pump them to get the calipers adjusted.
    Justin86's Avatar
    Medford, Oregon
    Ok I finally got a new monitor (17" LCD baby !!!) Yea I bleed them REALLY good, so I'm positive there is nothing in the lines. What about bench bleeding the master cylinder???? I never saw anything in the manual about that and there is no valve on the cylinder to bleed it?
    Even if I pump the brake it dosen't get stiff like it should and if the engine is running I could pump it 20 billion times before it would get stiff.
    10/Honda/Ridgeline
    NJ
    like vinny said, the master cylinder needs to be bled before its installed to the hard lines of the prop valves. the air pockets in them causes the spongy brake pedal feel. I did not do that to my sister's 4th gen, but its spongy half way thru and stiffens up after that and she apparently likes it that way, than the normal hard catch of the 4th gen brakes.
    Vinny's Avatar
    Aug 2003
    Here, not there
    Normally when you but a "new" master cylinder it comes with 2 plastic fitting that screw in where the brake lines go in, along with 2 rubber hoses. You attatch the fittings and lines, fill the master cylinder with fluid, then actuate the shaft until no air shows up in the lines going back into the reservoir
    Blkblurr's Avatar
    Dayton, Ohio
    Hey Vinny, your sig line is pretty funny!!!
    Justin86's Avatar
    Medford, Oregon
    yea I pulled the MC off my junked Se-i so I don't have those fittings but I guess I will have to pull the MC off and bench bleed it.
    Vinny's Avatar
    Aug 2003
    Here, not there
    go to Autozone and see if they have a new one. FENCO_REMAN M52286 Nothing else buy it for the use of the bleeders then bring it back they run like 56 bucks though.
    Justin86's Avatar
    Medford, Oregon
    I wonder if I can use the bleeders off my old calipers?????
    Vinny's Avatar
    Aug 2003
    Here, not there
    I think the threads will be different. I may be wrong but I think the MAster cylinder fittings are larger than the bleed screws off the old calipers. Worth a try though. Nothing else always do they "I bought a MAster cylinder and it doesn't have the fittings"
    Justin86's Avatar
    Medford, Oregon
    yea they are the same threads but the valve is too long for the MC, so I guess I will buy one.
    stupid POS.......bla bla bla
    Well since we are on the topic of you avatar, I gotz to say those are some fucking perfect boobs. Reminds me of my friends boobs, he he he
    Justin86's Avatar
    Medford, Oregon
    Well since today is my B-day I hoped that I would get my brakes working, well guess what they still don't. I bought another MC just so I could get the valves to bench bleed it. I did that and well I still have no pedal, I have to pump it many times. I checked the boosted again and it is still good. It feels like there is still air in there but where the hell is it? I have bleed the crap out of this system. ?????????
  1. brake fluid is leaking no brake power!!!!!! help
    By salgmz in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-31-2007, 07:10 PM
  2. parking brake and brake lamps always light
    By Dump0k in forum 3geez Accords
    Last Post: 05-22-2006, 09:50 PM
  3. Replies: 21
    Last Post: 04-17-2006, 07:02 PM
  4. 89 Accord LX - Brake/Horn Fuse Blowing When Brake Pressed.
    By Glowin Smurff in forum 3geez Accords
    Last Post: 02-25-2004, 08:34 AM
  5. emergency brake/ rear brake troubles
    By THE_LoserNextDoor in forum Performance
    Last Post: 07-03-2003, 04:51 PM
