I did this mod (quite) a few weeks ago. It resulted in a 3.5 MPG increase (from 26 to 29.5 MPG) on a car with a bad EGR (flashing code 12).
I'm writing this from memory and will update when I confirm the correct sizes or any discrepancies. The instructions are for an EFI car. You may or may not need the same tools for a carb.
Much thanks to keruhas184 for hosting the pictures.
Tools:
- Ratchet (a pipe or breaker bar may be helpful)
- A 1/4 socket (12mm I belive) and two extenders at least one of them 1/4 or one longer 1/4 extender needed to loosen the two nuts holding the EGR. 1/2 or 3/8 are too thick and the edge of the EGR doesn't allow them to be placed on the nuts. One of the bolts is too deep to be able to turn the ratchet if using only one short extension.
- 10mm (I think) socket for the bracket
- Screw driver
- Telescopic magnet
- Scissors and/or a cutting knife
- Paper
- Marker
- Asbestos free high temperature gasket material (#1966 is the cheapest one I found for $3.50 a roll (12" X 20"X 1/32") at Pep Boys)
00 On EFI the EGR is located close to the engine oil cap towards the firewall
01 Remove two bolts to loosen the bracket.
02 Remove the cap/clip off of the EGR with a screw driver. Remove the hose attached to the EGR.
03 While prying the bracket away (you can remove 3-4 more screws holding it on the right side to make it easier) loosen the two nuts holding the EGR in place using Telescopic magnet to prevent loosing them.
04 Remove the EGR then press the bottom of it against a piece of paper rubbing the edges to get the outline (or against the gasket material if it works for you or pick up a new gasket at an auto parts store for a $1 and mark around it on the gasket material. Then just cut the new gasket out with a cutting knife).
05 Fold the paper at the middle of the screw and diaphragm holes, then cut a half circle. You need to block the square hole with gasket material and cut out the round ones for the screws and the diaphragm so as to allow the EGR to function or rather fool the ECU into thinking it functions. Place the template on the gasket material and mark it's outline. Cut the gasket out with a cutting knife. Replace the EGR with the new gasket in place. I found the telescopic magnet useful when getting the nuts back on. #1966 gasket material is thin (1/32") so I double layered it just in case, but I'm not sure that was necessary. OP mentioned using aluminum flashing.
0001
0203
04![]()
05![]()
06![]()
07![]()
