Results 1 to 25 of 47
Thread: Block the EGR
    89cordlx's Avatar
    Black 1989 LX-I Coupe and 2000 EX V6 coupe
    Westerville, Ohio
    blocking the EGR
    my friend blocked his 97 dodge stratus EGR valve, and he said he noticed a difference in power. I don't totally understand why you feel a difference in power, isn't it just some sort of gas sensor?
    no.. it recirculates exhaust gas back into your intake... so basicly... like POS CARB said "your car breaths it's own farts"
    It's burnt and unburnt fuel and air.. it takes up space in the compustion chamber and keeps fresh air and fuel from going in.
    There are reasons it does this... 1 is to lower emissions 2 is to cool the engine some.
    89cordlx's Avatar
    Westerville, Ohio
    so I should not block it?
    Check my cardomain for sale items! Cardomain
    87 Lxi Hatch<-Blown Up!! 96 civic coupe
    Hot, Sweaty Florida
    Dont block it off!!! Your car will trow a code and will run like shit!! I tried blocking mine last year-it ran horrible!!!!
    Cold Air intake, Apexi N1 turbomuffler w/2.25 piping, H22 injectors,gutted cat, Dc sport header, accel coil, MSD ignition, Dropzone coilovers
    Justin86's Avatar
    Medford, Oregon
    Mine is not working and it keep throwning a code. It is starting to bug me enough I'm just going to buy another one to get my PGM-FI light to turn off.
    SEi User toastyghost's Avatar
    Mar 2002
    a 93 z34 that's getting parted out, an 86 accord lx that now lives in a j/y, and a 90 camry le that the state no longer allows me to drive. soon to be replaced with an aprilia rs50 or a derbi gpr.
    Harrisonburg VA
    It sounds like this would help if there were some way to trick the ECU. Does it read a resistance off of the valve to make sure it's working? Maybe you could just block the valve and then hook up a resistor to the pin-out that makes it look like it is functioning properly...
    ~<+045+ygH05+>~
    89cordlx's Avatar
    Westerville, Ohio
    to much work for me hehe, I'll just leave it how it is
    Hot, Sweaty Florida
    The sensor opens when the computer tells it to at a certain Rpm!! The Egr works while crusing!! The valve is like a button kind thing!!! you wood not be able to trick by resister!!! The easiest way is to get one from the junk yard for 20 bucks like i did!!! You really dont gain Hp without it!! It runs better with it!!!
    burgundy 86 honda accord/ brown 89 chevy caprice wagon
    its not used during wot anyways.
    WWW.ACCORDCENTRAL.COM
    Mar 2002
    Harrisonburg VA
    oh
    ~<+045+ygH05+>~
    89 LXI
    Maryland
    But how about guys that have the b16 intake manifold conversion, there's nowhere to mount the EGR to that manifold??? So basically they won't be able to use it.......
    Jul 2003
    1987-Gen2 Honda Prelude-FF-2.0L-MPFI-4 Cyl-5 Spd-PWR-BLK
    Ottawa
    THANK YOU!
    This is all I need to know!
    EGR is good...not bad!
    89 LXI
    Maryland
    Well, let us know how your car likes it or not.........
    DX User browntimdc's Avatar
    May 2004
    '88 Accord LXi 5-sp hatch
    DC
    Block the EGR
    Hi everyone,
    I'm new to this board. I have an '88 Accord LXi hatchback with 197K mi. Only 3 mods. Tokiko gas shocks, cold air intake and disabled EGR.
    I thought I'd share a clever way to disable the EGR at virtually no cost. I've been using this mod for several years on my current '88 and previously on my '85 SEi.
    I made a blind gasket out of aluminum flashing (two sheets) to go where the EGR tube attaches to the EGR valve. There's no hole for the exhaust gas to flow. I got a new standard gasket to use as a template and as a backup in case I had leakage. A thin layer of Permatex seals it up well. Instead of holes for the two attaching studs I cut slots in my blind gasket. That way when it's time for a smog test (every two years) I can just loosen the nuts and lift the blind gasket out with a pair of needle nose pliars. A five minute job. I also found I need plugs one step colder.
    Since the EGR valve still opens and closes the computer is happy. I can't say specifically there's more power but the throttle is more responsive. Sometimes the cruise control hunts up and down slightly.
    Oct 2003
    B20A SEi
    Oregon City, Oregon
    Quote Originally Posted by browntimdc
    Hi everyone,
    How is your gas mileage?
    May 2004
    DC
    Quote Originally Posted by Gregg86DX
    25 city
    33-37 highway
    Justin86's Avatar
    Medford, Oregon
    yea thats a pretty good idea for you that have testing.
    DX User FoX's Avatar
    1988 Honda Accord LXi 2 door Coupe
    Panama City Florida
    Red face
    Hi everyone,
    Any chance we can get some pics? I like the sound of this and would like to see exactly what you have done so i can do it..
    88 Accord LX 5 spd
    Warren,Ohio
    i didn't know they made an 85 se-i
    The City Is Mine
    1991 Civic STD
    Arbutus, MD, Baby
    they made and SE-i for the last years of the 2g and 3g (85 and 89)
    Daily Drivers Done Right
    88 Accord LX 5 spd
    Warren,Ohio
    i'll have to checm em out
    The City Is Mine
    Mar 2004
    1986 Honda Prelude DX, 1989 Volvo 240DL wagon died. 1987 f150 4x4
    Harrisburg Pa
    i also have been wating to do this mod. i was just ogin to weld some kinda plug in the end, but this sounds lieka better idea. in my state they just look to see fi you have the egr hooked up.
    -1986 Honda Prelude DX:
    pacesetter cat back w/Magnaflow muffler
    lightspeed header
    ngk iridium plugs
    Pacesetter short shifter
    94' integra coilovers
    k&n oil filter
    May 2003
    05 Legacy GT 87/accord/lx (rip)
    boston
    i'd like to see a pic of what he did. Screw the emissions if you can still pass the test
    LX User Wood9669's Avatar
    '88 Acura Integra RS
    Snohomish, Washington
    erm.. newb here..
    whats EGR?
    lol.
    May 2003
    boston
    Exhaust Gas Recirculation valve. On the carbed models the valve thing is on the passanger side of the carb. It cools down the air before spitting it out into exhaust to prevent high-temp emission gasses from forming. It also robs a bit of power from the engine because of an extra gas loop...
  1. New Kid on the Block
    By Blackbird_ in forum Newbie Introductions
    Last Post: 01-14-2009, 09:44 AM
  2. EGR block-off
    By custom in forum 3geez Accords
    Last Post: 09-11-2008, 11:13 AM
  3. New Kid on The Block
    By rally88lxi in forum Newbie Introductions
    Last Post: 09-30-2004, 09:02 PM
  4. A20 block.....and.
    By bodym1 in forum Performance
    Last Post: 05-17-2004, 12:55 PM
  5. Is the block in the 3gen the same as the block in a 90?
    By inflikti0n in forum 3geez Accords
    Last Post: 05-30-2002, 08:11 PM
