Results 1 to 13 of 13
Thread: lude tranny
    May 2004
    '89 Honda Accord DX, 2 dr 5 spd, '87 Toyota Pickup, 22R 5 spd
    Puyallup, Washington
    lude tranny HeLp!
    i have an '85 Honda Prelude Si Dual carb 2.0L 5-speed that stopped running, and i want to use it as parts. my question is, will the tranny from the Prelude fit on my '89 accord DX 5-speed??
    i hope it can, sure save me a lot of time, and a whole lot of money
    PhydeauX's Avatar
    Eastern Penna
    Something doesn't make sense here. Mostly the Si with dual carb part, unless you've converted to carbs and I though they started making the Si in 86. If it is a Si with an a20a3 motor then you can use the tranny in the accord. If its a 1.8 with dual carbs then you're going to need to do something about the axles too.
    andy
    May 2004
    crap, im having a hell of a time finding the engine code.
    it is and Si, on the door the date is late 1985, like nov. or dec., so it might be an 86 .
    i never drove the car, its not mine, just a friends car. i can't get a hold of him though!
    edit: the motor and tranny in the lude looks the same as my motor and tranny, but the lude has its valve cover off, and i can only tell that they look the same by looking at the the repair manual, and noticing that the valve are the same. so is the 1.8 litre lude engine a 12 valve too??
    PhydeauX's Avatar
    Eastern Penna
    Yes they are both 12 valve. If it is an Si is should be fuel injected, not dual carb. Look on the front of the block next to the trans near the timing hole. The engine code will be stamped there. If it is an 86 then the code will be either ET (1.8 carbed) or BT (2.0 efi).
    andy
    May 2004
    the prelude is a dual carb 2.0si.
    the rear end says its a 2.0si, and it has dual CV Carb, i think thats what it says.
    im assuming it will work, so im going to try in a few days or so.
    PhydeauX's Avatar
    Eastern Penna
    Well, someone's been messing with something then, and you need to get it strait before you comit to doing anything. All of the 2.0Si preludes came with the early BT/a20a3 motor and pgm-fi injection (the i in Si stands for injection). The cv carbs came on the base 1.8 modles only. If the car is a 1.8 then you're going to have to either swap the diff with an accord on or find out if you can swap the 1.8 hubs onto the accord. The 1.8 has smaller axles then the 2.0. If the car does turn out to be an 85 1.8L then its worth the hassel for the better ratios. If its an 86 or later 1.8 then you might as well junk it and find a trans from a 2.0.
    andy
    Justin86's Avatar
    Medford, Oregon
    well how about looking at the code on the tranny.......... to see if it is carb or EFI. You can use the carb tranny but you will ahve to do more work. Need to change the differental and the main and counter shafts. Then you will have some slight clearence problems with the presure plate. You will have to grind a little bit off the bell housing to ensure for good clearence.
    May 2004
    i have some of the tranny code, part of the sticker is missing.
    it says: GM- 339397
    the rest i dont know.
    May 2004
    sorry for double post, but where is the engine code on the 1.8 dual carb motor, or on the body of the lude?
    but something does not seem right with an Si with carbs, so today im going to talk to the guy that owns the lude .
    May 2004
    i went to the guy's work, didn't find him there, but i looked at a computer, and has nothing for a 2.0 carb for both 85 and 86. so i might just sell my taurus and get money from it, and then buy a tranny with the money.
    i believe it an swaped engine, or someone just wanted to look cool and put the 2.0Si on the back.
    thanks anyways guys!!!!!!!!!
    May 2004
    ok, the prelude is now mine, he is going to sign the title over to me soon.
    i was wondering, if i take the diff. on the original accord tranny, and put it on the the lude tranny, would the lude tranny be able to fit on ok?
    well what exaclty would i need to do?
    Justin86's Avatar
    Medford, Oregon
    well if it the Si tranny you don't have to swap the diff, but if you do use the accord you will also have to use the accord shafts for the gears to match up I belive. if you have the carb tranny you will have to swap the accord tranny casue the axles won't fit in the carb diff.
    PhydeauX's Avatar
    Eastern Penna
    To swap the diff you have to take both trannys completely apart. You need to swap the ring gear from the prelude diff to the accord (you'll need an impact wrench and remember they are reverse thread). If you want your speedo to be accurate you need to swap the speedo gear from the prelude to the accord dif housing as well (its pressed on and a pain in the ass to get off with out breaking). If you dont care about the speedo being off by a few mph then you can swap the accord speedo drive into the prelude case. Its not really a job for the faint of heart. You'll need to check the gear mesh etc as well when you put the new diff in.
    andy
  1. Lude or Ex-i tranny?
    By Elijah in forum Performance
    Last Post: 08-17-2004, 09:02 AM
  2. lude tranny on 3g
    By ACE_14 in forum 3geez Accords
    Last Post: 05-19-2004, 03:40 PM
  3. lude tranny
    By HaccordR89 in forum EFI Tech
    Last Post: 12-30-2003, 03:45 PM
  4. Lude/Teg tranny....
    By 88' Accord Ltd in forum 3geez Accords
    Last Post: 04-15-2003, 12:09 PM
  5. lude tranny anyone?
    By oldriceracer in forum 3geez Accords
    Last Post: 10-15-2002, 07:11 PM
