i will be running a b18a1 motor with dual webber sidedraft carbs, i need help finding a manifold. i was gonna go with 40 dcoe carbs, what do you suggest
S.Q.U.A.D. Engineering
www.squadengineering.com
Mark found his on EBAY. Im gald you are sticking with the carb because I really wanna see how it this engine setup turns out!!
'88 LX-i Coupe --- LS/Vtec
Let me know what you end up using and needing to set it up... 45's would be better, depending how fast you're goign to spin the motor. A 2.0l motor with good volumetric efficiency would only pull about 300cfm at 8500rpm... dual 40's might provide a bit more than that, but nothing's goign to be tuned or working optimally... I'd go with 45's for that reason (from what I've read)...
I don't know how much different the b18a is from the b20a... or even where to get everything to set it all up...
good luck though
bury the bach.
http://home.stny.rr.com/versanick/burythetach
pierc manifodls makea s intake mani but its liek 537 bucks or somethign crazy liek that! . you could have one made for cheaper than that. waht is nice about weber 40's or 45's they can hold boost!, you can turbo that thing!
-1986 Honda Prelude DX:
pacesetter cat back w/Magnaflow muffler
lightspeed header
ngk iridium plugs
Pacesetter short shifter
94' integra coilovers
k&n oil filter
