Results 1 to 4 of 4
Thread: need help finding a weber manifold to fit b18a1
    Jun 2001
    Boston MA
    Exclamation need help finding a weber manifold to fit b18a1
    i will be running a b18a1 motor with dual webber sidedraft carbs, i need help finding a manifold. i was gonna go with 40 dcoe carbs, what do you suggest
    S.Q.U.A.D. Engineering
    www.squadengineering.com
    Oct 2000
    '88 Accord LX-i
    Connecticut
    Mark found his on EBAY. Im gald you are sticking with the carb because I really wanna see how it this engine setup turns out!!
    '88 LX-i Coupe --- LS/Vtec
    LX User Versanick's Avatar
    Jun 2002
    1986 Honda Accord LX Sedan (RIP), 1989 (same) RIP, 86 Hatch Lx-i, JDM b20a, Gude headpkg, AEM cam gears/cai, thermal xhst, 2.5/3" lowrd tokico/groundctrl, 17" Seneca whls, hypereutectic pistons, .020" over, 13:1 comp
    Upstate NY
    Let me know what you end up using and needing to set it up... 45's would be better, depending how fast you're goign to spin the motor. A 2.0l motor with good volumetric efficiency would only pull about 300cfm at 8500rpm... dual 40's might provide a bit more than that, but nothing's goign to be tuned or working optimally... I'd go with 45's for that reason (from what I've read)...
    I don't know how much different the b18a is from the b20a... or even where to get everything to set it all up...
    good luck though
    Mar 2004
    1986 Honda Prelude DX, 1989 Volvo 240DL wagon died. 1987 f150 4x4
    Harrisburg Pa
    pierc manifodls makea s intake mani but its liek 537 bucks or somethign crazy liek that! . you could have one made for cheaper than that. waht is nice about weber 40's or 45's they can hold boost!, you can turbo that thing!
    -1986 Honda Prelude DX:
    pacesetter cat back w/Magnaflow muffler
    lightspeed header
    ngk iridium plugs
    Pacesetter short shifter
    94' integra coilovers
    k&n oil filter
  1. Weber carb on EL manifold?
    By 1980_accord in forum 1geez Tech & Performance
    Last Post: 08-14-2010, 12:16 AM
  2. manifold for twin Weber 45 DCOE's?
    By 3geeandEF in forum Performance
    Last Post: 10-21-2007, 10:23 AM
  3. Weber Carb w/ Manifold
    By A20A1 in forum Trading Post
    Last Post: 12-30-2003, 03:47 PM
  4. Weber Manifold
    By L3G10N in forum Trading Post
    Last Post: 10-04-2003, 07:59 PM
  5. Guaging Interest: Weber DCOE Manifold
    By bcookt06394 in forum Trading Post
    Last Post: 05-26-2003, 09:15 PM
