Results 1 to 20 of 20
Thread: Rear drum to disk possibility?
    10/Honda/Ridgeline
    NJ
    i know some of u think that i am stupid. BUt this is a question that no one i have talked to was able to answer me with a satisfactory answer. But with lots of parts cross reference and ease of fabricating, here is questiong.
    Will i be able to just slap on a disk at the rear, without getting all the knuckle and stuff from the SE-i? Except for the drum and disk, the knuckle and all other linkages do look similar. I dont mind getting stuff drilled out cause i have access to a machine shop. I wanna rip apart the whole drum set up on a junk 3g and take some pics and see how well they match up. I wanna get the rear disks pretty soon, but with time constrain and non-availability of a SE-i in a junkyard i am pretty much open for something like this, something to be made to fit.
    this is the DRUM set up
    this is the DISK set up
    Okay i cross referenced the parts and here are the exact match for both.
    75743 BEARING, HUB UNIT
    75744 BEARING, HUB UNIT
    61434 WASHER, HUB UNIT
    22426 WASHER, HUB UNIT
    22427 CAP, HUB UNIT
    52211 CAP, STABILIZER END
    75753 RING, SPINDLE
    75755 BRKT, R. RR. KNUCKLE
    75757 BRKT, L. RR. KNUCKLE
    75758 ARM, RR. (UPPER)
    75759 BUSH, RR. (LOWER)
    75760 BOLT B (10X55)
    75762 BOLT, FLANGE (10X20)
    75763 BOLT B (10X42)
    22397 BOLT, WHEEL (NAGOYA RASHI)
    14907 NUT, SPINDLE
    22582 NUT, BALL PIN (UPPER) (10MM)
    75764 O-RING (47X1.9)
    75765 O-RING (47X1.9)
    1414 PIN, COTTER (2.0X35)
    parts that are different on the drum
    75745 DRUM, RR. BRAKE
    75746 DRUM, RR. BRAKE
    75749 KNUCKLE, R. RR.
    75752 KNUCKLE, L. RR.
    75754 BRKT, R. RR. KNUCKLE
    75756 BRKT, L. RR. KNUCKLE
    illustration number ref : 1, 4, 7, 9, 11, 12
    parts different on the disk
    75766 DISK, RR. BRAKE
    75767 MUDGUARD, R. RR.
    75768 MUDGUARD, L. RR.
    75769 PROTECTOR, R. RR.
    75770 PROTECTOR, L. RR.
    75771 KNUCKLE, R. RR.
    75772 KNUCKLE, L. RR.
    57101 BOLT-WASHER (6X10)
    57102 BOLT-WASHER (6X10)
    55207 BOLT-WASHER (6X14)
    22400 SCREW, FLAT (6X14)
    illustration number ref: 4, 5, 6, 7, 8, 10, 11, 24, 25, 26
    So i dont see why we cant fit a disk on a drum place, without switching out EVERYTHING. u know what i mean? Any feed back would be awsome.
    Vanilla Sky's Avatar
    1999 Penalty Box
    actually, i've been wondering the same myself... i think it would be better to do if you're doing a big brake upgrade and leave the SEi parts for someone that doesn't mind stock SEi rear brakes
    i guess you can try and tell us how it is.
    if i had access to machine shop i would have done it long time ago.
    Jareds 89 LX-i's Avatar
    Apr 2001
    Black '89 Accord LX-i sedan
    Mills River, NC
    Good idea, but just one question.... where are you gonna bolt the caliper bracket to?
    I had thought of this once before too, heh
    -Jared
    10/Honda/Ridgeline
    NJ
    the bracket is not gonna be hard to machine, a AL 6061 should be a piece of cake.
    By the end of the summer, im gonna get this thing going. But some misaleneous parts with specific part numbers, can be omitted i am sure.
    I am suprised how u guys had the same idea, but never made a thread and put all the stuff there. Would have been a great help.
    LXi User Magny's Avatar
    Aug 2003
    1987 Honda Accord LX
    Cali Baby
    I wanna see this working first before I jump into this, it does look like everything is an exact match except the few parts that are different and needed. but isn't the bracket already on the sei arm so instead of fabbing up one just get that piece???
    1999 Penalty Box
    magny, yeah, but the idea is to be able to do this without the SEi parts...
    smufguy... i never talked about it because i thought the arms were totally different... i DID NOT know they were that similar... maybe i need to break the ones on my old parts car down and see what i think... i'm sure even for those that didn't wanna machine the bracket that you could pick a pair up at a dealer...i would think that's considered a needed part and will most likely carry those until these cars are pretty much gone off of the roads completely... that should be an easy part to get, even if we never see an SEi
    10/Honda/Ridgeline
    NJ
    magny, thats true. but its the last resort. LIke i said before. the only way i can get hold of them is to spend a good amount of money to get the piece from the dealership cause i cant find an SEI in the junkyard.
    Aug 2003
    Cali Baby
    oh, ok lol
    carotman's Avatar
    Montreal South Shore
    The rear drum knuckle is the same as the disk knuckle except the disc setup has a bracket to bolt the caliper.
    If you could manage to make a custom bracket and machine it onto the drum knuckle, it would work.
    10/Honda/Ridgeline
    NJ
    im gonna look at the bracket if i can from the local honda dealer today. ill see how it goes, if they actually have that bracket.
    1999 Penalty Box
    in reference to the bracket, any machine shop will make one for you, and since you have access yourself, that makes things even easier, then
    LXi User johnwc723's Avatar
    Feb 2003
    89 LX-i 5 speed
    Madison, WI
    might it be easier to obtain just a new SEi rear kunckle? i mean machine shop work can be expensive unless you are gonna do it all yourself and then there is the whole you could comprimise the saftey of your brakes bit
    Check out pictures of my car HERE
    "drop a 150 shot of NOS sticker on that bad boy and you can run 8s" -portugalfocus
    10/Honda/Ridgeline
    NJ
    Quote Originally Posted by johnwc723
    i have said that i cant find a SE-i here in the junkyard. so yeah, its either i make my own brackets or i get it from a dealer for the price i can sell my own life. So if u were following up the thread u would know. The machining will be done by me and yeah i can machine whatever i need and the warehouse is only 15 minutes away. I have built my car and have put about 20K miles in the past 7 months already and with soo much abuse, the car is still in one piece. So i can say i wont be fucking anything up and compromise safety? well with a use of common sense we can avoid that cant we?
    carotman's Avatar
    a caliper bracket will be hard to mount on the hub because there isn't really any place to put it. The SE-i knuckle has it's bracket built-in the knuckle. Keep us updated tough. it might help alot of people if you can manage to do it.
    Feb 2003
    89 LX-i 5 speed
    Madison, WI
    yeah its gonna have to be welded on there and stuff, you prolly should be able to do it, i just hope you got some nice rims to show em off, are you thinking a mig weld or are you gonna some how bolt that extra do-dad on there?
    10/Honda/Ridgeline
    NJ
    im not sure of it yet, but my main concern is to limit as any parts that i can get outta the SE-i, im still on the look out for it. Cause my 11" rotors in the back need to bnedefenitely shown i know this thread will be dead for a long time before i can update it when iget my hands on it. but i promise i willl update it.
    1999 Penalty Box
    haha, and no update, bump
    Justin86's Avatar
    Medford, Oregon
    I thought about this to. They make a rear disc swap for civics..........
    Not sure if it would work or not but the design should work for us. Might have to redrill the bracket they have or add spacers to the caliper, but it should work, for us, maybe even the ebrake lines might work for us???
    If not get a bracket made similar to that, should be really easy, then go to honda and get new calipers, and ebrake line, which are not cheap at all. One caliper is about 220.......... With that price you might be better using bigger rear calipers, ours are really small. The bigger rotors and stock calipers front and back will work really great 60-0 in 125 ft, but I'm looking for even better in the future. hope this helps some
    10/Honda/Ridgeline
    NJ
    u suckers. hhehehehe
    Well justin, i dont know if they can fit our knuckle tho, but its worth the shot. And without abs, i doubt if our cars can stop in 125 ft without locking up.
  1. [Suspension, Wheels, Tires & Brakes] Rear Disk Swap, with pics (for those with drum brakes)
    By OldSchoolSwap in forum How To
    Last Post: 01-26-2007, 02:45 PM
  2. rear drum shoes
    By ZackieDarko in forum Suspension/Wheels/Tires/Brakes
    Last Post: 11-01-2006, 02:07 AM
  3. Rear drum brakes !
    Last Post: 07-13-2002, 10:01 AM
