Results 1 to 10 of 10
Thread: Will this work ?
    accord HB ( metallic green)
    B.C Chilliwack
    Will this work ?
    Anybody body know if an 89 fuel pump will fit right in place of a stock 87 fuel pump - like does it mount the exact same or does the newer pump fit in differently into the carbed tank ?
    B.C Chilliwack
    Also I know there is a couple people who have used there stock fuel tanks in the conversion to efi, How did you do this - how did you run the return line into the tank ? did you make a hole in the tank !
    Please Help - this would help greatly because I planned on doing this, this weekend. I'm gonna stick with the stock tank for now if I can.(till I get some extra $ )
    If someone can give some tips, or even just let me know that this has been done before ? Thanks alott
    2.0Si User pimp86LX's Avatar
    2005 Mazda 3
    Ontario Canada eh.
    doesn't carb & efi run different fuel psi??
    B.C Chilliwack
    Sure does carb has about 8psi - I believe efi is around 30psi
    Thats why I am curious how you can use the carb tank also the extra line
    Banned
    Morgantown, West Virginia
    If your converting to efi, you need to swap tanks to an efi tank, the channels inside the tank are different and I think the whole pump assembly is different.
    nate.
    B.C Chilliwack
    Thanx , I've determined now is no time to cheap OUT. So yup I'll be getting one.
    Thanx
    carotman's Avatar
    Montreal South Shore
    the carbed tank can be used but your car might lean out on fuel if the level goes below 1/4 and you go in a curve for a long time...
    Other than that the pumps are almost the same
    CORRECTION
    for the carb settings: 2.6 and 3.3psi
    fuel injected settings:
    85-87 accord the pressure should be 33-39psi
    88-91 accord 36-41 psi.
    B.C Chilliwack
    well maybe that was part of my problem becasue my carb setup was pushin 6-8 psi
    and I have never even checked the stats on the efi press. I was just going by what I know - I had to change my dodge colts pump and it was around 30 psi so I was just estimating ya know !:p
    I wonder why the 88-89 has more pressure ?
    1989 DX R's Avatar
    Jul 2001
    1989 Accord DX ... 2001 Accord LX
    Texas
    It makes 10 hp more, due to compression and the intake valving.
    Good bye to the 1989 DX Type R. Hello 2001 LX.
    DX:
    "Four wheels, four doors, and no frills."
  1. After all that work...
    By raygv in forum 3geez Accords
    Last Post: 07-13-2005, 09:08 PM
  2. could this work??
    By geesnow in forum Performance
    Last Post: 08-13-2004, 04:24 PM
  3. Does it work?
    By bc86 in forum Classic Honda Community Chat
    Last Post: 08-03-2004, 04:50 PM
  4. will this work
    By ninja2571 in forum Performance
    Last Post: 11-20-2002, 07:42 PM
