Well im trying to change the pressure plate and clutch disk and I have got some of the things out of the way so i can get the transmission out so i can do what i have to, but i have run into a snag. In the how to section of the how to replace your clutch, it says "Remove the lower arm ball joint bolt from the right side lower control arm, then using a puller to disconnect the ball joint from the knuckle.", i thought ok shouldnt be anything difficult well for some reason i was wrong. I had a ball joint remover from removing the tie rod ball joints, but that doesnt seem to work and the puller i had didnt seem right cause it didnt get it off, as a matter of a fact it broke(but it didnt look all that strong in the first place). But i was just wondering if anyone who has done this can help me out please! Thank you in advance.
