Results 1 to 7 of 7
Thread: Damn Squeaking!!! Plz help..
    Jul 2002
    89 Accord LX-i coupe, Auto
    Missouri
    i have this squeaking coming from my front drivers side wheel. I can't tell where exactly it is coming from. I heard it last week and just though it was my control arms b/c i knew they needed replaced. Well I just got it out of the shop from getting them fixed and the squeaking is still there. It's killing me. It sounds like a rubbing/squeaky sound, and it gets faster and louder when i am going faster. Someone plz suggest something, this is gonna be the death of me. Thanks
    SEi User TeKKnoTeKK's Avatar
    Mar 2002
    88 Accord LX-i 5 spd.
    UT
    sounds like a ball joint or bushing to me.....may be worth spraying some wd-40 on them to see if it stops.
    -Aaron-
    hondaman87's Avatar
    88 honda accord DXE-i H/b 91honda accord wagon, 01 gsxr 600
    medford, mass
    it might be your brake system, a metal rubbing the rotor
    Jul 2002
    Missouri
    The ball joint and bushing were both replaced, so i don't think that's it. Thanks for the help though.
    maybe it's your brake pad indicator telling you your pads are worn low, only a rubbing will cause a noise that changes with speed really
    Eric
    2.0Si User Grant2k's Avatar
    Jul 2002
    I get that squeaking coming from the rear. It can't be wear indicators, but when i stand next to the car and bounce it it sounds like the ball joints. I think the ball joints are good though.
    86 Honda Accord LXI HB 5-sp
    Central California
    I'll throw this out their. Sway bar bushing can and do make noise. My rears make noise. But before I figured that out, tracing the sound lead me to all sorts of ideas. I was like a phatom noise that diffied(ms) to reveal its source. I finally figured it out and figured when I get a new rear sway bar I'll fix it then with the new mounts. Hey I even got under the CAR and bounced it from the underside, still I could not figure it out. It was when I had the suspension apart to install lowering springs and I moved the suspension and clearly heard the sway bar bushing make the sound. I wanted to take a hammer to it and show it a thing or two, grrrrr.
    Now I d
  1. squeaking???
    By HelenKellerrr in forum 3geez Accords
    Last Post: 05-30-2012, 05:38 AM
  2. Squeaking when turning
    By 88ACCORDLXFaSho in forum 3geez Accords
    Last Post: 06-20-2010, 10:00 AM
  3. squeaking
    By headbanger in forum 3geez Accords
    Last Post: 10-20-2009, 11:49 AM
  4. Squeaking?
    By erics86dx in forum Suspension/Wheels/Tires/Brakes
    Last Post: 10-12-2003, 09:59 PM
  5. Squeaking brakes.
    By Defiant[YD] in forum Classic Honda Community Chat
    Last Post: 06-15-2002, 04:49 PM
