Results 1 to 12 of 12
Thread: Seatbelt trouble
    LXi User Mattphi's Avatar
    Jul 2003
    88' Accord LXI
    Jax, FL
    Seatbelt trouble
    Ok i dont know how to describe this but ill try. The seat belt works perfectly fine except for one thing. After ur done with it being across ur chest and you unclick it...it does not wind back up. The mechanism on the right (on the drivers side door) that winds the seat belt from the bottom works fine. But the one on the left doesnt. I undid the door panel today and sprayed some WD40 in some spots where i thought maybe it needed some lube/ I am lost and have no idea how to fix this. Theres a bunch of labels saying "do not remove" and stuff so how do u fix this? THanks
    Vinny's Avatar
    Aug 2003
    Here, not there
    you replace the seatbelt. Drivers side always wears out faster because it gets used more, in theory. I wouldn't reccomend taking it aprt. mine does the same thing on the hatch. I may be ordering a new one if the one I'm getting with the black interior doesn't work any better
    Jul 2003
    88' Accord LXI
    Jax, FL
    the actual seatbelt or the whole "mechanism" thing?
    Vinny's Avatar
    Aug 2003
    Here, not there
    I think it only comes as an entire assembly, and ouch its 300 bucks
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    the seatbelts in the coupe weren't meant to be unclicked. as strange as it sounds, its true. and thats why the seatbelt won't retract all the way. You're supposed to get in while the seatbelt is still plugged in. Its kinda strange at first, but after you get the hang of getting in, its a lot easier. then you dont have to plug the seatbelt in all the time.
    Nothin' 2 Old Racing
    Bloodlust's Avatar
    1989 LXi Coupe (SOLD), 1998 Accord EX
    Line Lexington, PA
    Quote Originally Posted by NXRacer
    WTF? I didnt know that. Thats probably the gheyest thing Ive ever heard of. Oh well, seatbelts kill people, thats why I dont wear them.
    Aug 2003
    94 Accord EX....RIP 90 accord LX (3/2/06)...RIP 87 Accord LX 'junkbox' (06/17/04)
    Strong Island NY
    Quote Originally Posted by Bloodlust
    no its pretty ill, my girl had a lxi coupe an rocked it w/ the seatbelt always in, seatbelts really do work an at least it was better than her forgetting to put it on all the time
    --kevin :[
    cb7tuner.com .....
    I'd rather take my chances and die of a seatbelt slicing me in half rather than flying through the shattered windshield and flying 50 feet on the pavement.
    Aug 2003
    Strong Island NY
    Quote Originally Posted by GhettoAccord
    --kevin :[
    cb7tuner.com .....
    Nov 2000
    An interesting observation of mine is that regardless of whether you leave the seatbelt "plugged in" or not the retractors will still have to work. If it is plugged in every time you open and close the door you will be operating the retractors. So, either way it won't make them last any longer.
    89 Honda Accord Lx
    Ontario, Canada
    Yeah that is a common problem with the winding mechanism. Easy solution. Go out and buy yourself a 4 point harness, Never have to worry about that, and its look a lot better, and you never move from you seat!!
    Sep 2003
    86/honda/accord lxi
    Ft. Lauderdale, FL
    and the harness wont slice your head off.
  1. Silly seatbelt chime...
    Last Post: 01-04-2009, 08:53 PM
  2. Need help with Seatbelt Chime
    By cweed in forum Carburetor Tech
    Last Post: 10-05-2005, 05:13 PM
  3. Seatbelt Jammed
    By 88ACCORDLXFaSho in forum 3geez Accords
    Last Post: 01-18-2004, 10:57 PM
  4. antenna and seatbelt!!
    By nanaimo_honda_accord in forum 3geez Accords
    Last Post: 06-15-2002, 01:05 PM
  5. Passanger Seatbelt SAGGING!!
    By Jdub07 in forum 3geez Accords
    Last Post: 06-12-2002, 05:32 PM
