Results 1 to 7 of 7
Thread: engine warning light..
    88 accord ex-i, 88 prelude Si
    Canada
    my engine warning light came on for a second while doing a turn.. I haven't seen it since. Oil level is fine and I'll check all the other liquids later. Other than that, anyone have an idea what could cause it? I'll send it to the mechanic when i get my paycheque and get an oil change too.
    Now:
    -1988 Honda Prelude custom
    -1988 Honda Accord (to be fixed and sold)
    Soon:
    -some big 4x4 truck
    -91 Acura NSX
    http://www.hatetofeelband.com
    3Geez Veteran Bobs89LXi's Avatar
    Nov 2000
    2005 Civic LX Coupe
    Tualatin, OR
    If the engine light came on, your ECU has no doubt stored it in it's memory. The ECU is located under the driver's seat. It has a an LED that will blink a sequence of numbers, pause, and repeat the sequence. There is a ECU diagnostic chart in the FAQ section. To clear it, either disconnect the battery or remove the ECU fuse for approx. 60 seconds.
    Canada
    Thanks. According to my manual, the indicator light means there could be a problem with the EFI. Since it doesnt stay lit up, I imagine I have no real problem right away, but I'll still have it checked up on in a few days.
    Now to rip out the seat....
    Now:
    Soon:
    -some big 4x4 truck
    -91 Acura NSX
    Canada
    It doesnt really say anywhere how to find the light... I just noticed it out of the corner of my eye when i moved my seat up.
    Engine code 2
    Oxygen Sensor "B"
    defective circuit or unplugged / defective sensor
    Hrmm... any suggestions?
    Now:
    Soon:
    -some big 4x4 truck
    -91 Acura NSX
    Nov 2000
    2005 Civic LX Coupe
    Tualatin, OR
    Unfortunately, the fuel injected engine has two oxygen sensors, one right next to the other. They are located on the exhaust manifold. When one goes, the other is not far from dying, so it is best to replace them both. They are not cheap, although the Bosch are less spendy than ones from the dealer and work just as well.
    Canada
    Cool thanks. Hopefully I can do this job myself
    Now:
    Soon:
    -some big 4x4 truck
    -91 Acura NSX
    Sabz5150's Avatar
    1989 Accord SE-i coupe
    Richmond, VA
    Get an O2 sensor socket and a breaker bar. You'll need them.
    -5150
    glorious!
  1. brake light bulb out warning light
    Last Post: 12-08-2006, 11:14 AM
  2. Battery Warning Light?
    By pendejo in forum 3geez Accords
    Last Post: 11-08-2004, 01:11 PM
  3. Battery Warning Light II
    By meangreenLXi in forum Performance
    Last Post: 06-25-2003, 11:18 AM
  4. Battery Warning Light
    By zonecoaster in forum Performance
    Last Post: 06-10-2003, 10:18 AM
  5. Brake light (warning light)
    Last Post: 11-28-2002, 08:26 AM
