Results 1 to 2 of 2
Thread: cold cathode uv gauges
    Washington
    So I got an order in for my computer. Its a bunch of fans and wire loom and connector ends that when they are put into a cold cathode light source they look hella cool. They come with a ballast and all plus they are 12 volts. I was thinking a set of the 4 inch bulbs placed in the gauge pod with pauls gauges with the paint they use for the uv reactive stuff.
    Check out svc.com and let me know if it works. Im letting you know so you can be the guinee pig and not me. Plus I cant afford it at the moment
    HostileJava's Avatar
    Northampton, PA
    Sounds interesting, I thought a member had already done this? Should be in Appearance btw.
  1. Cold Can
    By RobbyKlotz in forum Carburetor Tech
    Last Post: 06-26-2004, 12:43 AM
  2. cold cathode uv gauges
    Last Post: 06-07-2004, 05:43 AM
  3. Gauges for 86?
    By Rendon LX-i in forum Interior & Exterior Care
    Last Post: 05-01-2004, 01:20 PM
  4. have you guys heard of cold cathode tubes?
    By bobafett in forum Interior & Exterior Care
    Last Post: 06-02-2002, 09:28 AM
