My UK spec Aerodeck CA5 A20 with injection automatic makes wierd noise since last couple of months. It sounds like electric fan motor with run out of greese in its bearing. I have checked but it not from fan motor. It is from some where around destributor but very difficult to pin down. Normally it starts when I pull out the car and then stops after one minutes. And start again sometimes randomly. The noise is in constant speed so its should not be either from engine itself or drive train I guess. There is no substantial problem so far but I wanna fix it before it becomes big problem cos Honda parts in UK are fxxxing expensive say twice or three times compare to Japan! Any help will be appreciated!
