Results 1 to 7 of 7
Thread: grease monkey check in
    86LXItooFAST4me's Avatar
    Dec 2003
    1986 Accord LX-i *** 2002 Mustang GT
    Austin, Texas
    ok, im about to pull my engine and do a bunch of thing and i just have one question. im replacing the timing belt with the kit and i know the crank notch needs to be pointing strait up and that the notches on the cam gear are to be strait across. but which way does cam notch point, up or down? and also, when I install the distributor, which direction is it supposed to point? im just double checking and i keep confusing myself. im sure ill pull the chilton out last time but isnt there two strokes in each cyl before it actually is through? so my point, is TDC always on compression turn?
    "Seriously, I have a half o' pack of Rolaids in my dipper" -Stewie (Family Guy)
    Car Pics
    vBGarage
    Vinny's Avatar
    Aug 2003
    Here, not there
    You want to set the flywheel to TDC. That will set the crank gear since its keyed. The cam gear has an indicator marked "up" The marks you need to look at are the 2 marks 90 degrees offset from the upmark. Those 2 notches need to be lined up with the valve cover mating surface. Just remember you need to align the cam gear after your crank is at TDC no the other way around. As long as you make sure the flywheel is at TDC, then align the cam gear marks you should be OK. Hell with chilton's. DL the engine section on Pauls site. Info's alot better
    k-roy's Avatar
    87 LX
    31.4 Mb Download, even on dialup its well worth the wait.
    http://www.pauldesign.ru/honda/shopmanual/62se300.pdf
    Props to Paul yet again.
    Dec 2003
    Austin, Texas
    thank you fellow grease monkeys!! lol thanks dudes. ill check out the Paul guide when i get home.
    Car Pics
    vBGarage
    LX User mag_pbg's Avatar
    1992 Acura Integra
    Kansas
    not to whore up this post, but I was abotu to change my timing belt and my dad is helping me except he never ever puts the motor at tdc, even when we did a change on the camry he didn't he just goes to work pulling of the crank shaft pulley nut. Everything always turns out allright, it just seems weird that everyone and every book says TDC, but he never does.
    "Popup headlights the pinnacle of 80's technology"
    Ram air intake bored out throttle body MSD Blaster coil Advanced ignition Ported Head with 3angle valve job and shaved Delta 260 cam Pacesetter header 2.25inch exhaust Mallory Hyfire 6
    Justin86's Avatar
    Medford, Oregon
    Pauls is ok but he doesn't have the 88-89 EFI stuff. Like I tell everyone, get the Honda repair manual , it has EVERYTHING, and you can get them for about $35. Mine has saved my ass before.
    Dec 2003
    Austin, Texas
    Quote Originally Posted by mag_pbg
    is your dad working on over head cam vehicals? thats kinda dangerous on OHCs but it can be done yes. but i have my head taken off and a colt cam installed so everything isnt in line anymore. but i have replace timing chains before without the engine at TDC but i new what i was doing.
    Car Pics
    vBGarage
  1. Choosing the right grease for your application
    Last Post: 02-01-2010, 10:20 AM
  2. Speedo cable grease
    By russiankid in forum 3geez Accords
    Last Post: 05-13-2008, 02:35 PM
  3. best product to clean grease?
    By T-Funk in forum Interior & Exterior Care
    Last Post: 09-23-2002, 10:04 PM
  4. best product to clean grease?
    By T-Funk in forum Classic Honda Community Chat
    Last Post: 09-19-2002, 03:40 PM
  5. What type of Grease?
    By Chris86Lxi in forum Classic Honda Community Chat
    Last Post: 07-11-2002, 06:44 PM
