The seatbelt / door light refuses to turn off even though the doors are closed and seatbelts are being worn, also the sensor on the ceiling where the rear view mirror mounts also was buzzing away, i could not figure out what the problem was since the other indicator lights shut off and the switches on the doors are not jammed and work properly. I was wondering if there is another sensor that i may be over looking that is causing this problem.
