Results 1 to 3 of 3
Thread: I fixed my antenna
    89 Honda Accord SEi
    St. Paul, MN
    Talking I fixed my antenna
    I was at the junk yard today getting a new main relay. When I removed the relay I noticed that there was a hole in the frame that the antenna went threw. I thought it over and came to the conclusion that the dash did not have to be removed to fix this problem. I searched for a few cars and found a antenna in good shape and started to remove it. I removed the fuse box and got myself another relay. I disconnected the antenna from the motor and pulled it up and out. No problem at all.
    When I got home I unbolted the fuse box and removed the main relay. I disconnected about half of the wire harnesses to get the fuse box far enough out of the way. I unbolted the 12mm mounting bolt for the antenna motor and detached the clip connecting the plastic tubing to the motor. I removed the motor and took the cover off and disconnected the antenna from the motor. There was dirt, rust and lots of harden crud in the gears of the motor. I cleaned it up really good. I took some weed wacker line and taped it to the end of the antenna and pulled it up and out. I cut it off and taped the weed wacker line to the new antenna and pulled it down. I connected the antenna back to the motor and reassembled the motor. Had a little bit of a problem getting the retaining clip back on. I bolted the motor back in. I replace the main relay with the one I got at the junk yard. Bolted the fuse box back and reconnect the wire harness. I pushed the antenna advance/retract button and the antenna went up and down.
    I thought it was relatively easy to replace and see no reason why anyone in this forum should drive around with a broken antenna. The antenna only cost me $1.00 at the junk yard and took about 2 hours to fix.
    i did the same thing and it works great.
    Vanilla Sky's Avatar
    1999 Penalty Box
    to me, it's a very worthwhile upgrade in the DX models, too... might not look too shabby relocated to the rear quarter, either
  1. Antenna for LX-i
    By okoka595 in forum Wanted
    Last Post: 02-10-2011, 01:13 PM
  2. antenna
    By drock in forum Wanted
    Last Post: 11-22-2010, 09:01 AM
  3. Antenna
    By ds650 in forum 3geez Accords
    Last Post: 11-05-2005, 05:50 PM
  4. wooooooooooohoooooo ! antenna fixed !
    Last Post: 12-07-2002, 10:25 PM
  5. Power antenna v. manual antenna masts
    Last Post: 09-08-2002, 03:53 AM
