Results 1 to 12 of 12
Thread: progressive springs?
    DX User 88'er's Avatar
    Jun 2004
    1988 Honda Accord LXi 2 door
    Lubbock, TX
    anyone know where i can find a good set of progressive springs to drop my 88 accord lxi about an 1" to an 1.5"? and what brands would you recomend?
    you posted in wrong section. it should be in suspension.
    first i don't know why you want progressive springs. i had Intrax springs on my old accord and it had progressive springs on the back. i didn't like them.
    bullard123's Avatar
    Nov 2003
    1988 Hatch LXI
    COLORADO SPRINGS
    I have sprint 2.25' springs on my ride. I like the stiffness they have. I'm thinking you have 17in rims sinse you only want a 1in to 1.5in drop. Right?
    Justin86's Avatar
    Medford, Oregon
    just go 1.5" drop with Neuspeed's it will look much better, or even lower???????? look at the stickies for different spring heights and stiffness.
    Moodybluesr's Avatar
    1991 Subaru XT6 AWD, 1988 Subaru XT6 AWD
    Urbana, IL
    The first sticky topic in the suspension forum deals with spring rates and drop rates. To obtain the results you are describing I would go with Eibach Pro-kit springs. They are a bit on the pricey side ($150-200) but Eibach makes a good quality spring.
    SiR's Avatar
    87 Accord LX
    Fort Lauderdale, Florida
    Quote Originally Posted by 88'er
    2" on my Suspension Technique springs. There are progressive, its really the only way to go if you dont want a adjustable setting. No one has ever complained about the ride of the car, and handles better then I could have wanted.
    Rooz
    Jun 2004
    Lubbock, TX
    well i've got stock tires and wheels right now, eventually i'll probably put 16's on, i dunno about 17's. if i drop it with progessive springs to 2.25 i just wanna make sure it'll perform good and look good. but i did find a damn good deal on some sprint springs for $123 today online. i just don't wanna go too low and be bottoming out on everything.
    bullard123's Avatar
    Nov 2003
    1988 Hatch LXI
    COLORADO SPRINGS
    Yeah, I used to bottom out with my sprint springs. Until I figured out why. I had too much junk in my trunk!!!! I had my stock springs in there ,my tool box, and a ton of other stuff I didn't need in there. Once I got it cleaned out I didn't bottom out anymore.
    Jun 2004
    Lubbock, TX
    so is it gonna be cool if i just replace my springs with the sprint ones and leave the stock struts for now?
    AZmike's Avatar
    Tucson, Arizona
    No, stock struts can't handle lowering springs. You would have a floaty, bouncy ride. The sprints are among the stiffest lowering springs available. If you aren't willing to get the correct dampers, at least get softer springs like the H&Rs or Neuspeeds. I wouldn't recommend the Eibachs since the rear rates are so low--your car would understeer even more than it does with the stock parts.
    Mike
    Busted_Blue's Avatar
    Jul 2003
    93 civic
    San Francisco, CA
    Actually...prokit is decent type of springs. This whole concept about more rear = oversteer isn't that simple. It's about balance and the spring rate differences are in percentages not number increase.
    Keep in mind 3geez are not a 50-50 car and we need stiffer springs in the front. My thought is even though there is more stiffness in the front it doesnt necessary mean it will understeer like a mofo.
    I'm just saying that low rear spring rates isn't the main key to understeer. It is about balance. You can after all, counter that with a bigger rear sway bar and add an LSD.
    I think my tokicos 1" springs are great because it did not change the spring rate ratio of front vs rear that significantly. It raise the spring rates almost equally so it didn't destroy Honda's balanced ratio by that much. Anyways, I love the steering on my car so I'm happy with it. Besides I paid $63 for the springs, thats a bargain.
    my two cents on spring rates.
    Jun 2004
    Lubbock, TX
    ok, both very good points. but now i'm totally not sure what i wanna do. here's what i'm thinking though. the sprint springs that will drop my car 2.25" which i wanna go that low anyways. with either kyb's or tokico's. with that throw off the feel a lot, and if so will it be good or bad. also what total setup (struts and springs) would you guys recommend for me if i want a 2.25" drop, eventually adding 16" wheels?
  1. 38/38 Weber, progressive?
    By sb_hbackDX in forum Carburetor Tech
    Last Post: 03-08-2006, 06:14 PM
  2. Progressive LED TACH
    By w00tw00t111 in forum Interior & Exterior Care
    Last Post: 05-02-2005, 07:31 PM
  3. progressive springs?
    By 88'er in forum Performance
    Last Post: 06-27-2004, 01:12 PM
  4. Progressive Neuspeed Springs?
    By Busted_Blue in forum Trading Post
    Last Post: 02-15-2004, 06:05 PM
  5. 1.5" drop progressive springs
    By smufguy in forum Suspension/Wheels/Tires/Brakes
    Last Post: 10-26-2002, 10:16 AM
