Results 1 to 15 of 15
Thread: Oilpressure gauge
    1987 Hatchback phreak project
    NORTH BAY ONTARIO
    Oilpressure gauge
    i read a few posts... it looks like a prety huge deal... it seems that it would be best if i took the whole oil filter holder off my old engine, put the adapter in, and then swapped it into my car.. htere isnt alot of room to work on it when its in the car unless i take the whole intake manifold off... i could, but i really dont want to drain the coolant...
    any tips and tricks?? i already have the tube ran, but hookin the sensor up is gonna be a prick
    BTW.. its a mech. gauge
    Travis
    Nov 2002
    1990/BMW/535iA
    New Orleans, LA
    The problem with taking off the oil filter base is that you have to remove either the oil pressure switch or the adapter for your mechanical gauge. Thus, it is probably best to install the adapter while the base is attached to the engine. I think Vinny mentioned before that he used a short wrench to remove the top oil filter base bolt (w/o removing the sensor), but I wasn't succesfull at doing the same. So your best bet is probably to unscrew the stock sensor (24mm wrench BTW) and install the adapter while working from underneath the car. Also, if you remove the airbox, you can get a decent view of the top of the oil filter base. With a helper to look from the top with a flashlight, you can simplify the process. Hope this helps.
    P.S.: I just changed my oil filter base gasket and removing and then lining up the base is a pain in itself, even after I removed the sensor.
    3axap.
    NORTH BAY ONTARIO
    ok.. if i take the sensor out while its on the car, will i need to drain the oil??
    Travis
    LXi User soljaboy2000's Avatar
    Jan 2004
    1989 Honda Accord LX
    Hawaii
    I also wanted to know a lil info about addiing an oil pressure guage such as if you take the stock sensor out, would it cause the oil light to constantly stay on and confuse the car that the pressure is low and affect the performance in any way?
    My 1989 LX Carb. A.K.A. "Hoop Ride" (R.I.P.)
    Idaho
    Just take the light out of the dash and run your new gauge....won't effect performance.
    Nov 2002
    1990/BMW/535iA
    New Orleans, LA
    And you don't have to drain the oil to remove the sensor. You do still need to remove the oil filter so a drain pan is necessary.
    3axap.
    Jan 2004
    Hawaii
    how come you have to remove the oil filter if the sensor is on top??
    Vinny's Avatar
    Aug 2003
    Here, not there
    Because the filter os bigger around then the base and its pretty hard to get something down to it from above, I can PROBABLY get to it with an extension, a flex extension and I think I found that a standard 12 point socket gripped it better than the metric one did.
    I didnt have ANY problems using the open end of a VERY small 10mm wrench to get the top bolt out. It was just a VERY sllow process. I'll be doing it again soonm on the hatch, I'll take a pic or 3 if I remember to
    NORTH BAY ONTARIO
    when i pull the huge sensor out, i wont have an adapter that fits the hole... i only got some little ones... or is tehre a tiny hole where the sensor goes??
    Travis
    Nov 2002
    1990/BMW/535iA
    New Orleans, LA
    Quote Originally Posted by dXsquared
    Travis
    The sensor is only big at the top. The part that threads into the oil filter base is pretty small. If you have an assortment of adapters, you should be able to find one that fits. Hope this helps.
    3axap.
    NORTH BAY ONTARIO
    it helps alot.. thanks guys
    3geez.com is the shizznit lol
    Travis
    Vinny's Avatar
    Aug 2003
    Here, not there
    Travis, If i can find my old sensor I pulled off the spare motor I will give you the thread size on it. That should help ya get an adapter.
    NORTH BAY ONTARIO
    thanks Vinny.. that would save me tonnes of time fuckin with all the adapters i got...
    Travis
    SEi User od2681's Avatar
    Nov 2002
    2003 Infiniti G35 sedan
    Houston Tx
    can someone post a how-to on this..pls
    NORTH BAY ONTARIO
    ill make one
    Travis
  1. Gauge Pod
    By TWOLOUDNPROUD in forum Classic Honda Pics & Videos
    Last Post: 09-18-2007, 02:55 PM
  2. Gauge pod
    By EricW in forum Classic Honda Pics & Videos
    Last Post: 07-01-2006, 04:05 PM
  3. OilPressure How To
    By dXsquared in forum 3geez Accords
    Last Post: 02-04-2006, 06:24 AM
  4. A/F gauge and Water Temp gauge
    By smufguy in forum 3geez Accords
    Last Post: 02-29-2004, 09:29 PM
  5. Gauge pod
    By Lt99 in forum Interior & Exterior Care
    Last Post: 03-24-2003, 03:57 PM
