My car almost siezed on the road a couple weeks ago, when I just recently checked the oil level before the incident happend and the level was fine. I get the car towed home. I Let the car sat for a day and checked the oil level which was a little above normal level then I took the valve cover off and noticed the gasket was cracked and replaced that.
Then I noticed the Vaccuum Advanced was in need of replacement and replaced that. Went to start the car again and when in motion i hear a grinding like popping noise, but no feedback movement from the grinding/popping noise.(like a shake) But the car wouldn't accelerate well at all I would be getting high rpms at 15mph turned the car off. I want to assume oil pump and something else causing this problem.
A Day later..
Attempt to start car again, and when I let go of the gas and keep the clutch down, the car will stall in Nuetral but when I don't have the clutch nor gas pedal down and in Nuetral the car stays idle with no problems but once gas is put into the engine it'll attempt to stall or just stall.
Any information on this would be great and any information on if I am looking at the wrong parts of this diagnosis.
Thank you..
