Results 1 to 14 of 14
Thread: Adjusting ignition timing
    LX User skull1441's Avatar
    1988/Honda/Accord DX 5-speed and 1990 300zx N/A 5-Speed
    Memphis, TN
    Question Adjusting ignition timing
    wat happens when i loosen the 2 nuts ( one of them shown in the picture) and move the dizzy clock and counter clock wise ??
    NA>TT Underway
    LX User TheMagi's Avatar
    Jun 2004
    87 Accord Lx-i H/B
    Livingston, Tn
    timinig adjustment....
    on FI cars, counter-clockwise advances the timing, clockwise retards it.
    same on carbed motors.
    Memphis, TN
    ok.... this is what im getting to.... i turned it all the way counter clockwise and gave me a lil extra juice but my coil started making a pssssss noise ( accel coil ) so i put it all the way to clock wise and it seem normal ...... is that pssss sound normal oooor does it mean its frying up?????
    NA>TT Underway
    k-roy's Avatar
    87 LX
    I got an Accel Coil and I have never heard a sound from it. And yes I have fucked with my timing all sorts of ways.
    10/Honda/Ridgeline
    NJ
    Quote Originally Posted by skull1441
    well, if u have too much ignition advance and run lean, esp u have no choice with your carb but to run lean, you will detonate. I detonated with 40psi and full ignition adv. So yeah, not good. im running 43 psi now, and im gonna get it back to where it was. Worse enough detonation to find small aluminum deposits on my spark plug tip. So run stock ignition timing or just stay below 5 degrees.
    Memphis, TN
    how do u know ur engine detonate??? !!!!!???
    NA>TT Underway
    10/Honda/Ridgeline
    NJ
    like i said in my above reply, pull the plug and look for small aluminum droppings kinda on the electrode tip. Also another good sign of too much ignition advance is abnormal cylinder head temp.
    I ran a compression test on my engine too. pretty weird numbers
    Cyl 1 - 165 psi
    Cyl 2 - 195 psi
    Cyl 3 - 185 psi
    Cyl 4 - 185 psi
    The cylinder that detonated was Cyl 3. Pretty interesting deal. I gotta set my ignition timing back, its still a little advanced. god damn, i need a timing light, or just eyeball it.
    Memphis, TN
    what is a normal psi ? .... i gotta check mine
    NA>TT Underway
    10/Honda/Ridgeline
    NJ
    Compression Test (300rpm and WOT)
    Normal: 171psi
    Minimum: 142psi
    Maximum Variation: 28 Psi
    LX User mr eff's Avatar
    Apr 2004
    89 Lx-i
    Berkeley, CA
    offtopic, but i'm curious how you have your car running with wide open throttle and keep it at 300rpm. is there something you have to set in order to test that?
    i am a car newbie though, so if like you do this sort of stuff with the engine on some sort of machine, my mistake!
    edit: drop it in neutral and lower the idle as far as possible? (just so you know i'm trying to think of the answer to my own question!)
    10/Honda/Ridgeline
    NJ
    Quote Originally Posted by mr eff
    You disconnect the injector resistor box, pull all the ignition wires and spark plugs. Inspect the plugs to see how the combustion occurs. Too black (too rich) medium to dark browinsh (near stoich). yellowish to golden (too lean).
    Have the car running, rev it up to 4 or 5K and just cut the car off while at that rpm and do the above.
    then after u have done the first things i mentioned, plug in the compression tester and try to start the car with the gas pedal floored. the rpms dont go any more than 500rpm, cause u got no spark and no fuel so its just the compression of the air in the cylinder and nothing else.
    When i did mine, i did not floor it, i had it about 3/4 open. so i dont know.
    Memphis, TN
    how do u cut off the gas if i got a carb ????
    NA>TT Underway
    10/Honda/Ridgeline
    NJ
    simplest way, pull the fuel pump relay out from ur dash fuse box, if not another way is to go to the rear of the car and open the service hole behind the rear seat on the floor pan under the carpet. then unplug the connector on the pump itself.
    So yeah, any of those methods work.
  1. need help with ignition timing
    By fijisac in forum 3geez Accords
    Last Post: 09-26-2009, 09:01 PM
  2. Adjusting TIming --- Trouble
    By gr3k0sLaV in forum 3geez Accords
    Last Post: 10-23-2002, 12:51 PM
  3. Ignition timing
    Last Post: 07-12-2002, 03:14 PM
  4. Adjusting my ignition timing tomorrow
    By gr3k0sLaV in forum Performance
    Last Post: 06-08-2002, 08:34 AM
  5. Adjusting the timing?
    By hondaisthebest in forum 3geez Accords
    Last Post: 05-09-2002, 01:09 AM
