Results 1 to 11 of 11
Thread: Problems After Vac line removal
    Aug 2003
    1989 Honda Accord LX
    Bowling Green, KY
    Ok, i just did the vacuum line removal. Now the car will do good to start, i can barely get it over 1000RPMs,and its smoking like a whore and bogs down when i slam it too the floor and i am dripping coolent from somewhere near the back of the carb it looks like. What should be adjusted first? A/F or idle?
    I can't figure it out...
    Robby Klotz
    Bowling Green, KY.
    3G'less at the moment. Working on getting an LXi
    SteveDX89's Avatar
    2002 Mazda Protege5
    New Freedom, PA
    Check to make sure you have the coolant line hooked back up to the carb. That could be causing the leaking. I forgot to do that and coolant was everywhere. If it's just a slow leak, check to make sure the clip is tight.
    Aug 2003
    Bowling Green, KY
    Quote Originally Posted by SteveDX89
    I can fix that when i get back home. Just a retard mistake... Any idea on the starting/idling problem...
    I mean, it feels like its getting 0 fuel
    Robby Klotz
    Bowling Green, KY.
    SteveDX89's Avatar
    2002 Mazda Protege5
    New Freedom, PA
    Only thing I can think of is to make sure you have vac line #14 hooked up to the back of the carb. I'm pretty sure that draws the fuel in. There are 3 ports on the back of the carb on top. It should be the one closest to the driver's side. That needs to be hooked up to manifold vacuum.
    Nov 2002
    1990/BMW/535iA
    New Orleans, LA
    What color is the smoke? If it is dark/grey you may be running very rich causing you to experience the bogging down and lack of response. Make sure the choke is not closed. If it is it will cause the engine to run extremely rich. It may start well with the choke in the closed position, but once it warms up it will do what you are describing. Also, since the choke uses vacuum to come off, you may have removed the vacuum lines that allow it to do so. If the choke checks out fine, you may need to readjust your mixture screw. Hope this helps.
    3axap.
    Aug 2003
    Bowling Green, KY
    On the Air/Fuel mixture screw... does screwing it IN lean it out, or richen it up?
    Robby Klotz
    Bowling Green, KY.
    SteveDX89's Avatar
    2002 Mazda Protege5
    New Freedom, PA
    Screwing in leans the mixture.
    Aug 2003
    Bowling Green, KY
    She is fixed and running great. Thanks guys
    Robby Klotz
    Bowling Green, KY.
    Feb 2004
    87 accord lx carbed
    N.H.
    you didnt say what you did to fix the problem if people come into this thread looking for advice on there problem they wont find the answer unless you give it to them.common curtiousy curtissy courtisy you know what i mean.
    "i dont have friends anymore and my favorite hangout is the junkyard but damn it runs good"..... by me. "i know i have not gotten laid in a while but trust me the blisters on my hands are from working on my car"...........by me.
    LX User rehv_Aerodeck86's Avatar
    Oct 2002
    86 Accord Aerodeck EX 2.0
    Tallinn, Estonia
    did u richen the mixture?
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    please go back to the how to section and look at the updated vacuum diagrams...
  1. vacuum line removal
    By stevenr816 in forum Carburetor Tech
    Last Post: 04-10-2018, 07:13 AM
  2. question about vacuum line removal
    By turabaka in forum Carburetor Tech
    Last Post: 09-03-2007, 03:36 PM
  3. vac line removal questions
    By HondaBoy in forum Carburetor Tech
    Last Post: 05-30-2005, 08:32 PM
  4. Idle problems after vaccum line removal HELP!
    By Racingcrazed2002 in forum Carburetor Tech
    Last Post: 06-01-2004, 03:52 PM
  5. vacuum line removal
    By pip in forum Carburetor Tech
    Last Post: 07-30-2003, 02:44 PM
