Had the rack and pinion replaced by a mechanic and continued to experience a power steering fluid leak. After bringing the car back to the shop several times I was told that he can't find any leaks on the rack and pinion and that the speedometer leaks power steering fluid into the engine. He added that pre 1990 Accords have this kind of speedometer setup.
Is this right or are they just tired of me showing up with the same problem? I have an 87 AUTO parts car. Can I use the speedometer from that car to fix the 89 MMANUAL that has the leak?
Thanks!
