Results 1 to 3 of 3
Thread: Help! Signal electrical problem!
    1988 Honda Accord
    Ontario, Canada
    Turns signals dont work! Help!
    So here's the symptoms...
    Put key to ON position, don't start car, turn signals and hazards work. Start car, the turn signals and hazards STOP working.
    I notice that when I have the key in OFF position and hazards on, as I put the key to ON position the 'flasher relay' on the fuse panel stops making the ticking noise and more like a grinding whining noise for a couple seconds and then begins to go back to ticking normally..... untill I start the car and it stops working all together.
    Any suggestions?????
    I was tugging on wire yesterday... perhaps one is loose.. but WHERE?!?!?
    Any suggestions?
    CoAsTeR
    88' Honda Accord LX
    www.coastersride.cjb.net
    Visit my website for pics and how-to's
    Jul 2002
    '87 LX sedan, auto, carb.
    Toronto
    ELECTRONICS is science of good contacts
    Hi, I not shure, but I think check Hazard signal switch on steering column first if yours there.
    All the best!
    Honda Accord: Nice pain or bad hobby?
    Jul 2002
    87 PRELUDE 2.0SI
    similar prob. with 87 prelude si
    my problem was in the ignition switch itself. i just removed the plastic covers around my steering shaft, and removed the switch contacts from the oppisate side from the key hole, and took a can of honda brake/contact cleaner to it.
  1. electrical problem
    By 86commuter in forum 3geez Accords
    Last Post: 07-22-2006, 10:35 PM
  2. passenger signal light problem
    By jlros75 in forum 3geez Accords
    Last Post: 10-12-2004, 03:59 PM
  3. Electrical Problem... Help
    By larnaton in forum 3geez Accords
    Last Post: 05-23-2004, 05:05 PM
  4. turn signal problem
    By jaminjames in forum 3geez Accords
    Last Post: 03-11-2004, 02:13 PM
  5. Electrical Wierdness, Signal Flasher Rate, etc
    By ascender in forum 3geez Accords
    Last Post: 09-08-2003, 10:30 AM
