Results 1 to 18 of 18
Thread: Car runs like a lawnmower!!!!! :(
    10/Honda/Ridgeline
    NJ
    I have a 89 efi and here is my problem. Today while driving, my car started to sound like it was running extremely rich. As in no power, u step on the gas, it sounds like a lawnpower, sputtering like hell. I get out and fine the pcv valve kinda loose, tighten it and its kinda okay, but still fucked up. I dont know what might be wrong.
    The manual said the following
    1. fouled spark plugs - these plugs are about 2 months old, took em out and they are brown color, which indicates normal wear
    2. misfiging - i dont know how it would misfire, cause my ignition is a lil retarted (i mean in degrees) and plug wires are where they are supposed to be, i dont know if the vaccumm diaphram is working, but hell ill see to it tom.
    3. Faulty ignition coil/system - im gonna get my spare coil tomorrow and see whats up with it.
    4. bad fuel delivery - i got damn 43psi at the fuel filter so wtf???
    5. clogged fuel filter - might be a possibility cause this came off the junkyard when i did my conversion. So i guess ill buy a new one.
    One more thing, i dont see any broken teeth on the timing belt so i dont think the valve timing is off. Also, driving back home from work, it did that, but once i started driving for about 15 mts, it went away. So i dont know whats up with it. Anyone who knows it can help me out, thanks.
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    hah hah reminds me of the time i got pulled over in my old coupe and the cop told me my car sounded like his lawn mower. I then proceded to offer to mow his lawn
    i know what you're talking about and my car runs kinda the same. If its running REALLY rough, you might want to clean your plugs n stuff to make sure they're all firing. Maye you have some bad gas?? If you buy watered down gas ( like what some AM PM stations around here sell) then it'll do that too.
    Nothin' 2 Old Racing
    LX User TheMagi's Avatar
    Jun 2004
    87 Accord Lx-i H/B
    Livingston, Tn
    Is it throwing any codes?
    Maybe O2 sensor...or throttle position sensor. Maybe.
    LXi User soljaboy2000's Avatar
    1989 Honda Accord LX
    Hawaii
    damn... 43psi......is that too much pressure for stock????
    My 1989 LX Carb. A.K.A. "Hoop Ride" (R.I.P.)
    Robs89LXi's Avatar
    May 2003
    '89 LXi Coupe
    Not sure what you mean by sounds like a lawnmower. My lawnmower has a Honda engine; sounds real smooth .
    Are you having any valve rattle? Is it doing it only when under load?
    Hawaii
    oh NM....I have carb.....my bad
    Robs89LXi's Avatar
    May 2003
    '89 LXi Coupe
    It's late. Go to bed.
    check your dizy. it may be worn out. check your spark plug wires and clean spark plugs.
    10/Honda/Ridgeline
    NJ
    thanks for the reply fellas. The Oxygen sensors are only 8 months old. The spark plugs are in good shape besides the one i pulled from Cyl #1. THe distributor looks fine, but im gonna switch out the rotor and cap and see whats up. im gonna get the fuel tank treatment and see if it fixes it.
    i mean the car runs strong or to say it ran strong for the past 7 or 8 months and helped me put 20K miles, yes 20,000 miles on it already and never broke down. i cant wait to get the motor from steve and start working on it so that it can go into my car and get the damn turbo put on.
    Vanilla Sky's Avatar
    1999 Penalty Box
    sounds like an ignition problem to me... do you throw a code when this happens?
    Robs89LXi's Avatar
    May 2003
    '89 LXi Coupe
    I think you are getting blowby.
    10/Honda/Ridgeline
    NJ
    Well, i did not have the check engine light on the dash or any cods off the ecu.
    I swaped out the Ignition coil, added in a fuel system stabilizer and cleaner/conditioner. And added in a quart of oil, Im a lil late on oil change about 500 miles overdue, but i got no money
    Now it runs fine. I gotta find a way to fix the stupid PCV next. Get a new one and fix it.
    YO ROB, what do u mean blowby, How do i get it and how do i fix it?
    Thanks for your help fellas. You guys rock
    Robs89LXi's Avatar
    May 2003
    '89 LXi Coupe
    Gases leaking by either worn rings or valve guides. It'll rob power, but you won't notice it as much in lower RPMs. You will definately feel it when you accelerate hard (or at least try to), but you get no power. Do a compression test if you can.
    chicago , il.
    what about the baro sensor, that compensates for fuel also . . . . .
    or a loose vacuum line within the "misterybox" . . . .
    10/Honda/Ridgeline
    NJ
    the baro sensor as in the map sensor? well i got a 4th gen one and its good condition.
    Rob i know what u mean and i already did a compression test two weeks back.
    Cyl 1 = 165psi
    Cyl 2 = 195 psi
    cyl 3 = 185 psi
    Cyl 4 = 185 psi
    I changed the ignition coil like i mentioned and the car runs fine with no hesitation whatsoever. Im still gonna get the fuel filter soon and fix that thing. Hopefully it will fix whatever is going on. I gotta take a look at my injectors too. I know one is leaking from the o-ring, its the cyl 3 injector. Hopefully things will be fixed soon.
    89 EX-i 2dr
    Ontario, Canada
    Man, i wish i knew what my car would run like with good compression..... it was something like 155, 135, 125, 135.....
    10/Honda/Ridgeline
    NJ
    Quote Originally Posted by Rex
    those are pretty bad numbers. damn. i was suprised even i got these numbers
    LX User rideredorgohome's Avatar
    Feb 2003
    1988 Honda Accord "S" model, Carbureted
    London,Ontario
    Quote Originally Posted by NXRacer
    Well from my experience water in the fuel will cause car to "buck" and misfire violently, then quit if it is a lot of water. It doesn't sound like that.
    "There are good cars out there, and then there's Honda. Ride Red or Go Home..."
    Current Mods:
    K&N Air Filter
    Blue Anodized Oil Filler Cap
    Chrome Shifter Knob
    PIAA Wipers
    Dynomax Performance Cat
    Dynomax Muffler
  1. Mean Lawnmower?
    By Nio in forum 3geez Accords
    Last Post: 01-26-2010, 06:37 PM
  2. B20 Runs 9.31
    By -$MOKIN- in forum Classic Honda Pics & Videos
    Last Post: 04-09-2009, 07:39 AM
  3. U T O P I A ! ! ! Now, It Really Runs!!!
    By it's paid for in forum 3geez Accords
    Last Post: 02-09-2004, 10:24 AM
  4. IT RUNS!!!!! IT RUNS!!!!! I Can't Believe It!!!
    Last Post: 01-29-2004, 06:48 PM
  5. Rad Fan Runs 24/7...how do I fix?
    By BootMachine in forum EFI Tech
    Last Post: 10-21-2003, 09:25 AM
