ICEMAN707
i still doubt the a20 is a non interferance engine. the pistons are at deck height on TDC. what makes you think there will be room there for an open valve? why do you think timing alignment is important when changing the timing belt? other than bent valves and destroyed pistons, you can also damage the engine by way of detonation when the compressed cylinder gasses shoot back into the open intake valve instead of out the exhaust valve into the exhaust manifold, and blow your intake manifold, valve cover, and head, etc. in any case, a snapped timing belt=damaged engine. just cus you could start it by way of luck, doesn't mean the damage hasn't been done. don't tell me the engine still purrs like kitten after that happens. LOL.
higher compression pistons, VTEC lobe, and mild to wild cam profiles certainly affect the way the engine is....certainly won't be non-interferance anymore, that's for sure.
