Page 1 of 5 12345 LastLast
Results 1 to 25 of 115
Thread: What happens when your Timing Belt goes?
    Mar 2003
    1987 Honda Accord 2.0Si ........ Manual of course.
    Melbourne, AUSTRALIA
    g'day Boys
    My 87Si is at 188,000 km's and its common knowledge that in most Honda's you change the timing belt before you hit 100,000km's. I'm guessing the previous owner probs did it around 90-95,000 km's. I'm about to get my clutch done and I'll do the timing belt at the same time (will cost me $850 all up).
    Just wondering about what happens if the belt snaps before it's changed as I'm getting a little vervous about the Km's and the belt letting go soon. Plus, if I launch the car in 2nd from say 2000rpm to about 5000rpm, the engine sometimes stops pulling for a split second sometimes as if it misses a few revs or something....
    Can the car get seriously fucked up if the belt snaps while you're driving?
    Cheers
    LX User TheMagi's Avatar
    Jun 2004
    87 Accord Lx-i H/B
    Livingston, Tn
    on this type engine, absolutely
    the valves risk hitting the pistons if the belt should break.
    Feb 2004
    89 accord lxi
    down by the bay
    Dude, replace that belt and replace it NOW. Mine was doing the same thing like it would miss every once and a while if you were driving at steady rpm. That little jump on the tach it does is because a section of the teeth are stripped out. If you don't wanna break down and have to rebuild the head, fix it now.
    LX User FatDave's Avatar
    Nov 2003
    1993 Accord SE coupe
    Valley park Mo
    if you're really lucky the belt will strip a few teeth at low rpm and the engine will die with no damage done, if you're not so lucky the belt will snap and the pistons will slam into the valves and make a nice boat anchor out of the head
    Never explain--your friends do not need it and your enemies will not believe you anyway.
    Elbert Hubbard.
    2.0Si User accordlxi2.0's Avatar
    1986 honda accord lx (r.i.p) 1990 acura legend LS
    chicago , il.
    umm this has been a big debate.
    the engine is NON-INTERFERANCE.
    if the belt snap's the engine's fine.
    i had a friend who dogged his 3g, everyday and did'nt change the belt at all.
    it lasted for a while.
    well doggig as usual it snapped.
    he cranked quite a few time's too.
    it was the belt which was really worn, and we replaced it, it started ranned too.
    a few guy's on this board had the belt's break, replaced it , it was fine . . .
    LX User mr eff's Avatar
    Apr 2004
    89 Lx-i
    Berkeley, CA
    yeah i've heard the engines are non-interference, meaning if the belt snapped you shouldn't damage the valvetrain. of course, don't let it break to find out... get the thing replaced while you're doing the clutch!
    Jun 2004
    87 Accord Lx-i H/B
    Livingston, Tn
    that's good to know....
    Quote Originally Posted by mr eff
    I thought it was in interferance motor
    LXi User johnwc723's Avatar
    Feb 2003
    89 LX-i 5 speed
    Madison, WI
    hmm i think that honda engines are interference, i have heard of people messing up their engines when the timing belt breaks, one of my friends had a lude with the a20a4 and his timing belt broke and many of the valves got bent (maybe holes in the pistons too i dont remember) and he just gave up on it
    sometimes people get lucky when the timing belt breaks in our cars and no major damage (or even noticable damage) happens, id replace the belt tho if you can!
    Check out pictures of my car HERE
    "drop a 150 shot of NOS sticker on that bad boy and you can run 8s" -portugalfocus
    ok, well yes, its an interferance motor. think of it like this. your T belt breaks, the crank is still turing pushing the pistons up and down, but your cam shaft has stopped not letting the valves open and close with the pistons up and down run. you can get lucky as a few people have to where it broke just at the right time where the valves were not fully open. thats how they didnt bend the valve. moral of the story, its worth every penny you have to replace that damn T belt. and as your replacing the T belt, go ahead and replace the water pump and the other belts of the engine. believe me the water pump will like to go out on you many times after changing the T belt. actually if you change the alternator belt which also runs the water pump sometimes soon after that the water pump will go out when its pretty old.
    Aug 2001
    1988 Accord DX 5spd
    Dayton, OH
    Yes it's an interference motor. I talked to a mechanic at Honda's Civic plant about my timing belt breaking and he was amazed that no valves got messed up. He said every one that he has seen has had internal engine damage.
    chicago , il.
    then why did my friend's 3g start up okay.
    and some of the people on this board said thier's was fine . . .
    plus i heard that 90 and up accord's ARE.
    i don't know . . . . .
    LX User rideredorgohome's Avatar
    Feb 2003
    1988 Honda Accord "S" model, Carbureted
    London,Ontario
    ok well it is really easy to take the cover off to check it. get a haynes manual at Auto Zone or something and it will tell you what it looks like when it needs to be replaced. any worn edges, fraying etc will indicate it is time to change it. i would not recommend changing it yourself, unless u r a mechanic. the engine is an interference engine. the belt was one of the first things i did when i first got the car for safety's sake. don't forgrt that our cars have power steering as well and not only can you punch a few holes in the pistons but when u lose power u will also lose steering.
    "There are good cars out there, and then there's Honda. Ride Red or Go Home..."
    Current Mods:
    K&N Air Filter
    Blue Anodized Oil Filler Cap
    Chrome Shifter Knob
    PIAA Wipers
    Dynomax Performance Cat
    Dynomax Muffler
    LXi User Oyvind Ryeng's Avatar
    Mar 2004
    Tromsø/Norway
    The car will steer fine without pressure from the PS-pump. A little hard, but it would still steer.
    Feb 2003
    London,Ontario
    Quote Originally Posted by Oyvind Ryeng
    I meant to put "power" in there Steering without it is not fun and almost dangerous IMO at lower speeds
    Current Mods:
    K&N Air Filter
    Chrome Shifter Knob
    PIAA Wipers
    Dynomax Muffler
    2.0Si User Neuspeed87lx's Avatar
    Jul 2001
    96 Civic (Turbo lsvtec) /87 accord lx/95 civic dx
    Agawam, Mass
    my timing belt snapped..... not good things happened.... dont like it snap .... replace it now and save the trouble
    Jay
    LX User KoNEY's Avatar
    Jul 2003
    95 Skivic Cx HB
    Winchester, TN
    well, what does "interference" mean?? and what is this talk of '90 on up accords being "non-interference"??
    Mar 2004
    Tromsø/Norway
    Interfering= The piston will hit the valves if they are open when piston gets to TDC.
    Non-interfering= The piston will not hit the open valves at TDC.
    May 2004
    87 LX // 89 LX-i
    Cleveland, OH
    I thought all hondas were interference, as are a majority of cars, they're cheaper to produce. Thats the one thing i loved about my 87 camry, non-interference=no stress
    chicago , il.
    by sean
    "for the last fucking time the a20a is not an interfernce engine. i dont know when where or how it got around that it was but the bullshit stops here. put a belt on it youll be fine "
    sorry sean i had too,peep's are confused again.
    ****** 1994 nissan maxima SE ******
    LXi User AccordAddict's Avatar
    Jul 2004
    1986 Accord Lx-i
    Alpharetta, GA
    its an interference engine, im sure of it , j/k . im glad the owner before me put a new belt on .
    Performance Mods: 2.25" Cat Back Exhaust System, 3ARacing Muffler, Short Ram Intake, Accel Super Stock Coil, 9.3mm APC Spark Plug Wires, Autolite Double Platinum Spark Plugs
    chicago , il.
    i have a confession to make i never replaced neither t- belt's, cause they looked new, i gotta check this one though . .
    Mar 2004
    Tromsø/Norway
    Is the A20 NOT an interfering engine? Are you guys absolutely sure about this? This is news to me!
    chicago , il.
    nope, plus one person knew the clearance's and he said they would'nt touch.
    plus, one guy at my job, an acura owner say's that also what contribute's to prevent the engine from hitting if the . . .
    oh my head hurt's wait . . .
    okay you know on the block then the piston, then the top of the block, well if the piston does'nt surpass that or does'nt reach to the top then that's a non- interference engine.
    i've seen the diff between a interfernce and non-interference
    a mitsubishi galant (poor engine)
    and a a20a3 whoa!@
    Mar 2004
    Tromsø/Norway
    Quote Originally Posted by accordlxi2.0
    Are you thinking about the deck height?
    Anyway, if the cam does not lift the valves high enough to make them come into contact with the piston @ TDC, it's all fun 'n' games. That means one doesn't even have to change the t-belt or tensioner to prevent engine damage.
    chicago , il.
    umm yea, but i'm glad that's over with, you know this should be a sticky.
    something like:
    ALL NEW MEMBER'S ( OR ALL MEMBER'S) A20 SERIES ENGINE'S ARE NOT INTERFERENCE.
  1. I need timing belt help
    By dmitch31 in forum 3geez Accords
    Last Post: 05-30-2007, 10:40 AM
  2. Timing Belt
    By 89HondaAccord in forum 3geez Accords
    Last Post: 03-10-2005, 07:54 PM
  3. Timing Belt
    By 89HondaAccord in forum EFI Tech
    Last Post: 03-09-2005, 04:30 AM
  4. Timing belt
    By 89AccordLvr in forum 3geez Accords
    Last Post: 03-20-2003, 05:13 AM
  5. Timing Belt.....
    By 3G Jester in forum 3geez Accords
    Last Post: 01-03-2003, 12:06 PM
