Results 1 to 11 of 11
Thread: Changed timing belt
    LX User mag_pbg's Avatar
    1992 Acura Integra
    Kansas
    Changed timing belt
    Today me and my dad decided it was high time to change the timing belt. From start to finish it prob. took around a hour to take everythign off and put everything back on. The hardest part was the stupid crank pulley nut, we had tried a couple of weeks ago by putting a 1/2 inch socket on it zip tieing it to the shockes and cranking the motor over but all that did was brake the extender for the rachet. We ended up havig to barrow a impact gun and go at it for prob. 5 min. or so, thats how tight it was. But it was prob. worth it.
    "Popup headlights the pinnacle of 80's technology"
    Ram air intake bored out throttle body MSD Blaster coil Advanced ignition Ported Head with 3angle valve job and shaved Delta 260 cam Pacesetter header 2.25inch exhaust Mallory Hyfire 6
    87accordlxph's Avatar
    Carbed 1987 Honda Accord LX & Black 4th gen Accord (91)
    Petrolia, Ontario Canada
    Yeah that crack pully can sure be a bitch to loosen.
    I'm having a very hard time trying to take mine off to take off the cylinder head
    cause I'm parting out a EFI Accord to do a Carb to EFI swap, but I guess I'm gonna keep on trying.
    Glad to hear that you did the timing belt yourself w/ your dad, saved a lot on labor for sure.
    -Mike from P-Town!
    Mike's Clean Cnd A20A2 5 spd Champaigne Beige Sedan Accord, Eh!
    B-Day: 07/87 in Alliston, ON Canada
    The best mods are mods that can be modded over and over again.
    SteveDX89's Avatar
    2002 Mazda Protege5
    New Freedom, PA
    Quote Originally Posted by mag_pbg
    All you did was tighten it more by doing that. The engine turn counter clockwise so it turns the bolt clockwise which tightens it. Good to hear you got it off. Mine was a bitch and I couldn't even get it off with an impact gun. I had to take it to the dealer.
    10/Honda/Ridgeline
    NJ
    Quote Originally Posted by SteveDX89
    i wonder how it will be when i try to take my motor apart before hauling it home
    DX User momo8517's Avatar
    Aug 2003
    1990 Honda Accord LX
    Ithaca, NY
    easy way to break crank pulley: put it in 1st and tow it backwards some!!!
    thats also a good way to destroy something.
    1990 accord.
    5-speed.
    Millington, TN
    Easiest way is air power.
    Air compressor and impact, spins it right off.
    Phil
    May 2003
    05 Legacy GT 87/accord/lx (rip)
    boston
    disregard...
    Just broke 2 1/2" 30" and an 24" extension bars and bent the 18" trying to get that mofo of a bolt off that crank pully. DAMMIT!!!. I even put most of my weight on it and still didn't crack that bolt loose!!!
    That 17mm bolt is still on there strong I'm sure.
    I'd have to go with Phil on this one!
    AIR FREEKIN POWER!!!!
    I'm getting a compressor with a freekin high torque air impact gun to get this f@#$in thing off.
    Arrrr, first time that I actually broke a tool or 2.
    Proud of that. Hehehe I'm gonna get my money back from those cheap extensions. Don't buy forged steel tools, they bend then break.
    Maybe go carbon steel like my 1" dia. 1 foot long cheater pipe.
    Now that thing didn't even bend one bit.
    Ok sorry for venting I gatta go lie down
    Good luck!
    -Mike from P-Town!
    chicago , il.
    someone on the borad, i forgot, took the timing belt off by the camshaft, which is a good idea . . .
    Mar 2004
    1993 Acura Integra B18A1
    Stockbridge Ga
    Well timing belt and othe acces. belts and my leaking intake grommet hose thing will be fixed in the next week all for the total of $400 parts and labor.. yeah nice huh.
    At least the bastard will be running right though!
    "I'll head back to the neverland ranch with a peanut butter jelly chiken tuna sandwhich.."
    LXi User BlueBead's Avatar
    May 2004
    '87 Carbed Hatch(RIP), 88 FI sedan w/ power group, '73 Jag w/ 350lump
    Vancouver Island BC
    if you stick a long screwdriver in against the ring gears where you look at the timing marks and get someone to hold it in while you break the crank bolt loose it works pretty good. It should have around 80ft lbs or so torque on it. G'luck
  1. timing belt
    By 8855A in forum Carburetor Tech
    Last Post: 07-28-2010, 12:49 PM
  2. Timing belt
    By jamsaccord in forum 3geez Accords
    Last Post: 12-14-2007, 03:54 AM
  3. Timing belt
    By Tcoop1468 in forum 3geez Accords
    Last Post: 01-15-2006, 06:40 PM
  4. Help with timing belt
    By 88LX-iSedan in forum 3geez Accords
    Last Post: 03-30-2005, 08:17 PM
  5. Timing Belt ?
    By zerotap in forum 3geez Accords
    Last Post: 02-10-2004, 10:47 PM
